replacing exhaust
stefan442
replacing exhaust
Post by stefan442 » Mon Mar 03, 2014 7:07 pm
My 3rd and 4th section has rusted off... so I am going to replace all 4 sections. No point buying the last two for 90 when I can replace whole lot for 125.
Is there anything else I could do whilst I am under there?
Gasy
Re: replacing exhaust
Post by Gasy » Mon Mar 03, 2014 7:28 pm
Diff oil
Transfer box oil
Waxoyl
stefan442
Post by stefan442 » Mon Mar 03, 2014 7:50 pm
I'll check the fact sheets...
I assume this is ok for my 97 2.5 td?
http://m.ebay.co.uk/itm/190774251065?nav=SEARCH
Post by francophile1947 » Mon Mar 03, 2014 9:01 pm
Is your Bongo a winter model, with 2 batteries and a switch, with a picture of an engine on it, near your right knee?
stefan442
Post by stefan442 » Mon Mar 03, 2014 9:22 pm
nope
Post by Northern Bongolow » Mon Mar 03, 2014 9:54 pm
thats the wrong one then.
you need the 3 piece system. :wink:
see the different parts here.
stefan442
Post by stefan442 » Mon Mar 03, 2014 10:19 pm
woo, lucky me! I nearly bought it, thanks for that!!
Maybe ill just get the rear two sections then! First section was quite rusty though!
Hmmm, by the looks of it the rear two sections are identicle. (flexi and silencer)
http://www.ebay.co.uk/itm/MAZDA-BONGO-C ... 19cdf5b733
should do the job?
why does the bongo need two silencers? the 40-200 and 40-500 on http://lushprojects.com/bongopartsmk2/c ... o=.html#12
stefan442
Post by stefan442 » Fri Mar 07, 2014 8:35 pm
right... changed exhaust! A couple of things...
This bracket i had to angle grind one of the studs to get the 2nd section off.... at the time i didnt realise it was welded on. I might be able to drill out the stud, or just buy a new one?
It bolts on between the first and 2nd flexi section, i have just put some m12 bolts in for now. Seems pretty sturdy.
This bracket wasn't bolted back, and there is a big hole behind it! What is this? I have bolted it back into place now, it holds the first solid section from engine.
stefan442
Post by stefan442 » Sat Mar 08, 2014 2:39 pm
No ideas? :(
