The central locking has stopped working on my 1997 Bongo. I only ever used the key to open it. On occasions it was intermittent and I was putting it down to the main battery being low as it was mainly happening in the morning. However it has now stopped altogether.
I've read the various posts on the subject this afternoon and done the following: changed the fuse in the interior fuse box, manually open and locked the door by pushing the interior drivers door button. It didn't open or close the other doors. The electric windows are still working. I don't have a 'meter' to check for voltage etc.
Looking at the posts on this subject it could well be a broken wire and may require a new loom. However can anyone suggest any further tests or doing anything else to check what might be causing the problem?
