which Sprinter wheel arch
Getting quotes for my wheel arches and was asked to confirm the year of Sprinter - he admitted that they remained unchanged for a long time and suggested 2000 era, E.g.Mercedes Sprinter 95-06 Rear Wheel Arch ME459ALAAN. Is this right?
My most local body shop suggested he cuts back the inner then bonds and seals the remaining solid to the replacement outer. He could refrabricate the inner at extra cost (about a day) but does not think it necessary unless going for a prestige renovation. I've read on here about individuals rebuilding the inners but when having it done commercially time is (lots of) money. Worth it? Any views?
Chris with BertieB
- mikexgough
Re: which Sprinter wheel arch
These ones..... it does for both sides... used them from mine and Klokkerholm brand
Remove inner panels if able.... and waxoyl inside several times before replacing the panels... obviously waxoyl the outer arch too
Yes that is the correct arch to use, I think I was the first to find and use these. I also just cut the inners back so no rust was there then bonded and sealed the outers to the inner( as well as welding the outside). The reason I decided to do it this way was to eliminate the scenario of 2 skins which may trap water between them. You now have just one outer skin and you can see and feel exactly whats going on in future. I have since changed Bongos but would love to see my old one to see how its holding up. It's about 2 years since they were done so should be a good test.
Thanks Mikex and Stuc. Good to hear I was on the right track after reading your earlier posts on these arches.
Chris
Chris
Chris with BertieB
David Edwards
Any chance of making this post "Sticky" could be really hand for peeps in the future and save all the searching.
David Edwards wrote:Any chance of making this post "Sticky" could be really hand for peeps in the future and save all the searching.
Just visit your corner shop.
http://www.igmaynard.co.uk/bongo/arches.htm
And silly me, I didn't check the fact sheet either
http://www.igmaynard.co.uk/bongo/member ... arches.pdf
It answers my question about the year, which I did not get from searching the forum back to 2011. Experience of the best way to deal with the inner is really useful when challenging a body shop - would this be worth considering for inclusion in the fact sheet.
Edit: and maybe a warning about decals. Perhaps I was being stupid but had not thought about the decals having to be taken off for respraying the affected panels.
Chris
Chris
Chris with BertieB
I've never seen the fact sheet on arches, and I have just realised I'm not a member anymore,(emailed Ian to sort this)so I will have a look when I can get on. Am I allowed to add to the fact sheet if there is anything I feel would help.
MyBongoiscalledDave
- Bongonaut
Hey Guys,
Sorry to resurrect such an oldie here.
I’m having a lot of trouble sourcing some rear inner arch replacements which I think are referred to in the ancient post.
Any ideas?
Kind regards,
Adam
Any ideas?
Kind regards,
Adam
Put Mazda bongo arches as a search on eBay there’s quite a few. As far as inners rears go they are a pain especially drivers side as it’s such a stupid shape I had to do mine in about 6 pieces stitching it all together
MyBongoiscalledDave
- Bongonaut
Mmm, I had a feeling that the inners were going to be a nightmare. Is there anything that kind of fits that can be hammered into a shape where they do fit?
Have you got outer arch all cut away
MyBongoiscalledDave
- Bongonaut
Not yet. It’s at my mates workshop. He said it’s gonna cost £1500 (plus respray) with a couple of other bits so I’ve told him to stand down. I don’t have that sort of cash. I’ll have to drive it for now, (it just passed an mot) and I’ll get it done in the summer.
I’ll buy a welder and learn a new skill while I’m at it.
Get a reasonable second hand mig of eBay Facebook gumtree etc get a hobbyweld account for argon mix gas rather than the tiny bottles and a reactive face mask and you’re good to go putting arch on its pretty much spot welding. To start anyway. Once you’ve trimmed Down new arch panel and outlined it against old then the fun starts
TheLongRoad
Make sure you remove the interior trim and anything that can catch fire ... it’s not unusual for vehicles to catch fire otherwise. I’ve got the full side conversion and rock n roll to remove, plus interior trim before my garage will go near it.
2002 Friendee 2.0 ltr Petrol.
