Passenger rear side window
jerrycarrj
Post by jerrycarrj » Fri Feb 14, 2014 8:05 pm
Hi can anyone out there give me some guidance on replacing side window as some sweet person or persons has decided to shatter mine. I've seen some on eBay around £50 but need to know if I can fit them myself. I have 1996 2 ltr auto top tinted black windows, cheers guys.
Re: Passenger rear side window
Post by Bob » Fri Feb 14, 2014 8:21 pm
This is very easy.
Sorry to hear of your bad luck, common sense will show you how to do it.
jerrycarrj
Post by jerrycarrj » Fri Feb 14, 2014 8:38 pm
Thank you for that will order the window and fit it with confidence cheers
Post by Bob » Fri Feb 14, 2014 8:53 pm
No worries, screws just undo and one pin easily knocks out with a drift. One way is much easier but, of course, I can't remember which way.
Test gently and it should be obvious. :wink:
Edit: Try and make sure you retain the fittings from the broken one incase the replacement doesn't have them.
mountainmummy
Post by mountainmummy » Fri Feb 14, 2014 9:44 pm
We managed to replace ours and we're rubbish at both car stuff and DIY :oops:
Good luck.
Sara
Why, oh why did I chose such a naff forum name????
jerrycarrj
Post by jerrycarrj » Sun Feb 23, 2014 6:03 pm
Window arrived Friday. Saturday morning I set out to replace window, removed old one easily so far so good. The replacement was easy to see how it fitted but needed a helping hand to hold window in place as I made good the fixings . Surprisingly easy job thought something would go wrong it usually does. Cheers
