head gasket
head gasket
head gasket went last night on the way home from work, i am so gutted, phoned mazdabongo.com £1600 without seeing it and i got to get it there somehow so bloody annoyed
						Re: head gasket
Really bad luck.
						Re: head gasket
Could be worth a shout, and they come to You.
http://www.contractmechanics.co.uk/
Example
New Cylinder Head (Including bolts, gaskets etc)
From £870
Example
From £870
Re: head gasket
Don't forget it's vital to find out why it went.
Good luck.
						Good luck.
Re: head gasket
What are the symptoms and what diagnosis has been done so far? Sometimes a small leak in a pipe or hose will allow air into the coolant system so it becomes pressurised and water is forced out the expansion tank overflow. This might cost a few pounds to fix and then bleed the system. On the other hand, if the temp gauge has been up into the red, then the cylinder head could be cooked too.
						Re: head gasket
did not let it go into the red managed to notice it just before but steam from the exhaust and white gunk on radiator cap
Re: head gasket
Doesn't sound too good. I don't recall every hearing of anyone ever finding signs of oil in the coolant before. The gasket usually fails at a point where combustion gases can get into the cooling system. There is only one small oil feed pipe between the block and the head (sealed by an O ring) whereas there are about 20 points where the coolant circulates between the two.
It may be worth eliminating eliminating the turbo before pulling the engine apart. It has feeds for oil and coolant so a failure there could result is oil in the coolant as well as coolant getting to the combustion chamber or the exhaust.
Re: head gasket
so i got hold of this chap, dont know if anyone has had dealings with him but he sounds like he know's his stuff
[img]Contract Mechanics
The Garage
Unit 9 Churchlands Farm Industrial Estate
Bascote Road
Harbury
Warwickshire
CV33 9PL
01926 612932
Tel. 07551578462
email:[email protected]
MAZDA BONGO/FORD FREDA 2.5 TURBO DIESEL CYLINDER HEAD KIT
Parts and services we cover when replacing cylinder head
1 brand new cylinder head casting assembled by ourselves,refaced valves,new seals,camshaft & followers checked and assembled,all clearances set,new exhaust studs fitted,new thermo sender fitted.
2 full victor reinz headset ,brand new headbolts.
3 brand new radiator assembled with fans inspected by ourselves.
4 brand new water pump ,new thermostat
5 major hoses (top/bottom rad,top/bottom engine,over starter hose,)
6 8litres of concentrate antifreeze (50/50 mix)
9 brand new ngk glowplugs
10 new cambelt
11 all labour,cleaning materials,sealants,clips,refacing.
BASIC PROCEDURE
On removal of cylinder head we do full inspection of engine block,inspecting cylinder bores,block face,water jackets,core plugs,etc.
Cooling system fully checked hoses,water pipes,sealing gaskets,etc.
ASSEMBLE
Block face refaced,all tapings cleaned,all galleries cleaned, etc.
All parts assembled using manufacturies tolerances(torque settings).
Cooling system replemished and bleeding done.
The procedure above is only a basic description of the work we actually do.
You are welcome to watch us do work and we will explain what we have done as we work
ALL WORK AND PARTS ARE WARRANTIED FOR 12MONTHS/12K MILES.
We come to you and supply and fit for £1350.00
Whether you use us or not please feel free to contact use with any questions ,advise
Thank you for contacting use .
Cheers Simon
[/img]
The Garage
Bascote Road
Harbury
Warwickshire
CV33 9PL
01926 612932
Tel. 07551578462
10 new cambelt
BASIC PROCEDURE
ASSEMBLE
Cheers Simon
[/img]
Re: head gasket
I think he's well known and work is recommended by others on here.
						Re: head gasket
If he's known and reputable then price wise it sounds good - I paid £1056 for cylinder head alone at reputable dealer and I had to get the van to him.
Dave
						Dave
Re: head gasket
well the bongo is going to have the work done today by simon,,,, so fingers crossed we will be on the road again and looking forward to our trip to paris in may
						Re: head gasket
Sounds good.
						Re: head gasket
our bongo is up and running and sounds and feels so smooth,had a little tear in my eye when he started up.
A BIG thank you to simon,what a worker came down a long way to help us out and through the odd shower did a brilliant job cannot recomend him enough.
a very happy bongo owner
				al & chris
 - Tribal Elder
Re: head gasket
That's brilliant. Did they replace all that was on list? Radiator etc. the price looks excellent to me.
						- Dr Fingers
Re: head gasket
Did he come all the way to Ramsgate from Warwick?
That's service.
Derek
						That's service.
Derek
