52mm Gauges
Moderator: Ian
Spencer54
52mm Gauges
Post by Spencer54 » Thu Jan 09, 2014 3:11 pm
What three would you fit to assist the Bongo?
I was thinking water temp/volt/oil temp might be the best bet.
Or fit two volts, one for each battery.
Looking around here I've seen boost gauges, but not sure what I'd get out of knowing that.
Re: 52mm Gauges
Post by francophile1947 » Thu Jan 09, 2014 5:04 pm
I'd fit oil pressure instead of oil temperature.
winchman
Re: 52mm Gauges
Post by winchman » Thu Jan 09, 2014 5:33 pm
I just have a Volt meter and a engine temp taken from the back of the cylinder head
Simon Jones
Re: 52mm Gauges
Post by Simon Jones » Thu Jan 09, 2014 6:39 pm
I've fitted a boost gauge on my everyday car & it's not massively exciting on a turbo diesel as the boost pressure is not as variable as on a petrol engine. Won't tell you anything worth knowing, unless the turbo stops working, but you'll soon spot that.
the1andonly
Re: 52mm Gauges
Post by the1andonly » Fri Jan 10, 2014 12:32 am
Any idea as to where you would fit them?
must it be 3 eg a drop down panel
Simon Jones
Re: 52mm Gauges
Post by Simon Jones » Fri Jan 10, 2014 12:54 am
This would be a good option for 3 gauges: http://www.ebay.co.uk/itm/RADIO-SLOT-BO ... 20dd9fe580
Spencer54
Re: 52mm Gauges
Post by Spencer54 » Fri Jan 10, 2014 10:47 am
Exactly what Simon says...
Something like this http://www.youtube.com/watch?v=CnIwvsbaxdc
Although this looks saucy - but not sure I need that level of detail.
Not unless it can monitor how knackered the rad hoses are or rusty the arches have got :oops:
CKC100
Re: 52mm Gauges
Post by CKC100 » Sat Jan 11, 2014 12:08 am
I fitted two small digital volt meters to the top of the clubby hole in the middle, one for each battery. Not the round ones, but looks good. I wired them through a couple of switches so they can be turned off when not camping.
helen&tony
Re: 52mm Gauges
Post by helen&tony » Sat Jan 11, 2014 6:32 am
Errrr....where do I start?....I have 12 gauges and 2 screens....SO FAR.... :lol: :lol: :lol: :lol:
Re: 52mm Gauges
Post by Northern Bongolow » Sat Jan 11, 2014 10:12 pm
start with the most important one helen, the coolant system pressure gauge, (2 bar) you know, the one that measures the internal pressure in entire system, the one you look at and stop the bongo before it dumps the coolant out of the tank if the pressure gets too high 8).
helen&tony
Re: 52mm Gauges
Post by helen&tony » Sun Jan 12, 2014 5:11 am
Hi Ady
As you know, a lot of those gauges were added when we were plotting how the cooling system works ...quite a few years back.... :lol: :lol: :lol: :lol:
Funnily enough, one that I do find useful, is the one on the bottom hose when doing bleeding....tells you EXACTLY when the stat opens, and when the system is fully working....I wouldn't be without it!...Many of the other gauges are superfluous to general motoring, but I'm using them to assess other projects...
Personal opinion on gauges:
Water temp. Oil pressure, volts, turbo, water pressure.
Just my opinion, but if you have an old classic...and the Bongo is that! , then you need to keep a eye out on the engine....and that list will keep you informed, gauge wise. I'm told that the Bongo ECU is pretty rudimentary, so not all that good at fault finding, so a few "extra" gauges look like a good investment!
Return to “Pimp My Bongo”
