Temperature Gauge/alarm placement with Double Din
Moderator: Ian
Spencer54
Post by Spencer54 » Thu Jan 02, 2014 11:22 am
Try as might I can't seem to find any images of one fitted to a bongo
I like the one in the BMW clock, but I was thinking of fitting a double din stereo with all gizmos.
So where else do you guys fit these?
Any images would be a bonus!
One I'm settled I can buy the right version and crack on :)
Thanks kindly
briwy
Re: Temperature Gauge/alarm placement with Double Din
Post by briwy » Thu Jan 02, 2014 11:38 am
Gasy
Post by Gasy » Thu Jan 02, 2014 5:02 pm
I've got me window blind switches were briwys put his
So I put mine here but was going to put it in big cubby hole next to me other gauge
Have seen them to right of drivers knee in the little cubby hole
Nice temp alarm briwy like your style
Spencer54
Post by Spencer54 » Fri Jan 03, 2014 10:54 am
These aren't the Haydn ones correct?
Simon Jones
Post by Simon Jones » Fri Jan 03, 2014 11:50 am
They're an inexpensive Chinese gauge which Haydn did buy a batch of & then offer to a few members for a free trial. I think the majority developed faults & were subsequently returned. He never supplied any more of that type.
Mine would get up to temperature & then stick there regardless of the actual temp so was pretty useless. Even though there are 2 sensors, it only displays the highest reading so you cannot switch between to the two so you can't monitor water & head temp independantly.
Pros: cheap & the lack of options makes it simple to use
Cons: reliability, the case is intended to be panel mounted & the lack of options means you are limited on diagnosis
The best ones are TM2 / TM4 available from Haydn's daughter Jo who now looks after the coolant alarm business.
winchman
Post by winchman » Fri Jan 03, 2014 1:19 pm
Gasy wrote: Image
Look at the blue gauge above I have a TM4 mounted above that position with a sticky pad.
It works fine
I also had one of the other type and found it unreliable so changed it for a TM4
Spencer54
Post by Spencer54 » Fri Jan 03, 2014 5:52 pm
As per you get what you pay for.
I'm obviously missing something, I can see the blue gauge and the Chinese gauge - but no TM-4?
Gasy
Post by Gasy » Fri Jan 03, 2014 6:00 pm
That blue gauge is now fitted to the top of that cubby hole next to a double 12v cigar socket
The Chinese temp gauge has not given me any probs been over 9 months now
And I would notice if it started to go wrong as I'm used to the way it climbs and decrease in temp
With what the van is doing ( that one came from Canada , I'm happy with it . It's as accurate as my gas analyser thermometer probe , and rises and falls at same speed as that )
winchman
Post by winchman » Fri Jan 03, 2014 9:48 pm
Spencer54 wrote: I'm obviously missing something, I can see the blue gauge and the Chinese gauge - but no TM-4?
I havent got a picture to hand so I commented about the one allready posted.
I have mounted my TM4 in the cubby hole, just above were the photo shows the blue gauge.
Spencer54
Post by Spencer54 » Sat Jan 04, 2014 12:33 am
Gotcha! Obviously having a blonde moment :lol:
Gasy
Post by Gasy » Sat Jan 04, 2014 9:35 am
We're ever you put yours make sure you can see it easily when driving
Because I think you will find even tho it has an alarm on it
You will do nothing but watch it when you are driving
(So you don't have to move your eyes to far off the road your supposed to be watching when driving)
winchman
Post by winchman » Sat Jan 04, 2014 12:40 pm
Good point I mounted mine here but then couldn't see it whilst driving
haydn callow
Post by haydn callow » Sat Jan 04, 2014 10:33 pm
http://www.coolantalarm.co.uk
Also BMW Clocks
briwy
Post by briwy » Sun Jan 05, 2014 2:10 am
The one in my pictures came from Canada, cost around £25 if I remember correctly.
Worked perfectly for the couple of years plus that we had that Bongo.
mantaJim
Post by mantaJim » Sun Jan 05, 2014 1:10 pm
This is an image of my TM4. There was a thread on this but I think it may have been deleted as I can't find it.
http://s1287.photobucket.com/user/jiman ... a.jpg.html
V6 Mushroom
Return to “Pimp My Bongo”
