Diff and Gearbox oil
Simon Jones
Re: Diff and Gearbox oil
Post by Simon Jones » Wed Dec 04, 2013 12:57 am
Good find Mike. Interestingly, it indicates the transfer box it is good for 'lifetime vehicle'. It's also got the fuel consumption figures, but I think it best not to look at those :lol:.
Alacrity
Post by Alacrity » Wed Dec 04, 2013 2:01 pm
ALL oils should be changed at some point. Filled for life - what does that mean? Think about it. When the transmission or transfer box fails that's the end of its life! Regular oil changes will lengthen that life.
Many auto gearboxes - my field - are filled for life according to the vehicle manufacturer. BMW, Audi, Jaguar & Land Rover to name but a few who use ZF transmissions & claim 'lifetime fill' see here for what ZF themselves say about it.
Also sometimes a component (lets say transfer box) may develop a very slight leak from somewhere that isn't obvious. Over the years it will get low on oil & damage will result, regular preventative servicing (as NathM is suggesting) will pick that up sooner rather than later.
Remember though - use a good quality CORRECT oil. Oil is an engineered component like any other vehicle part, using the wrong/poor quality oil can do more harm than good. Cheap often isn't cheap in the long run.
NathM
Post by NathM » Wed Dec 04, 2013 3:15 pm
Alacrity wrote:ALL oils should be changed at some point. Filled for life - what does that mean? Think about it. When the transmission or transfer box fails that's the end of its life! Regular oil changes will lengthen that life.
Yeah, what he said!!! 8)
and i think if a few people remove the magnetic drain plug they'll confirm that its not quite as clean in there as expected! Dont wait til your in the middle of nowhere with a mashed up transfer chain/box! and become a statistic of 'I've never heard of a transfer box problem'
NathM
al & chris
Post by al & chris » Tue Feb 04, 2014 6:25 pm
Syntran 2 ? Just done a search for it is that miller oils syntran 2
Post by Northern Bongolow » Tue Feb 04, 2014 8:49 pm
yes, millers, in my opinion the best oils you can get, expensive yes, but 3 years after changing EVERY fluid in my bongo its never missed a beat.
mines a 4wd manual box and thrashed every day------------, but maintained regularly. [-o< [-o< .
al & chris
Post by al & chris » Wed Feb 05, 2014 12:33 am
Northern Bongolow wrote:yes, millers, in my opinion the best oils you can get, expensive yes, but 3 years after changing EVERY fluid in my bongo its never missed a beat.
Thanks, will try to find some. Did you also use this in transfer box, yes suppose you use everywhere even in manual gearbox.
Post by Northern Bongolow » Wed Feb 05, 2014 10:14 pm
yes, in STANDARD diffs/transfer box and manual box.
on the wifes i used the same for diff but millermatic atf DM, MAKE SURE ITS DM AS THERE IS A UN,LOWER SPEC.
http://www.millersoils.co.uk/commercial ... ctor=Fleet
http://www.millersoils.co.uk/automotive ... sector=Car
