rear heater fan
Nutcase
rear heater fan
Post by Nutcase » Thu Oct 10, 2013 10:04 pm
Just fit new rad and long o/s metal pipe which goes to rear heater , bled system etc, all hoses hot, temp stable, bubbles appear to have stopped but for some reason rear fan has stopped working, now is this a coincidence or have I done something wrong, and could it just be the fuse. Cheers :D
Simon Jones
Re: rear heater fan
Post by Simon Jones » Thu Oct 10, 2013 10:08 pm
Likely to be a coincidence. Check the fuse and also double check you've got the 'rear' switch on up front.
Nutcase
Re: rear heater fan
Post by Nutcase » Thu Oct 10, 2013 10:14 pm
Hi simon, hope so, and wot do you mean exactly, thanksjase
Simon Jones
Re: rear heater fan
Post by Simon Jones » Thu Oct 10, 2013 10:19 pm
If you have manual controls, there will be a rocker switch marked 'fan' or 'rear' to the right of the steering wheel. If you've got digital controls, there will be a push switch marked 'rear' on the panel. Without this being switched on, the rear fan will not work.
Nutcase
Re: rear heater fan
Post by Nutcase » Thu Oct 10, 2013 10:26 pm
Ahhh right, ill have to check, its an Nreg manual 2.5td tintop if that makes any difference, many thanks simon
Simon Jones
Re: rear heater fan
Post by Simon Jones » Thu Oct 10, 2013 10:30 pm
Re: rear heater fan
Post by Bob » Thu Oct 10, 2013 11:12 pm
And switch on the front fan. :wink:
Re: rear heater fan
Post by Northern Bongolow » Fri Oct 11, 2013 6:21 pm
we have all done it sometime :shock: .
