cmm303
Post
by cmm303 » Sat Oct 05, 2013 10:46 pm
I have just modified my temperature gauge. I chose to put 110 ohms across the terminals so I should be getting a slightly lower temp. reading than if I had opted to use 100 ohms. I took BertieB out for a 30km run. Generally the gauge sat just above half way mark. Going up a long steep hill, country lane so not fast but with revs about 3k evenutally the temp got to about 80%. As soon as the gradient eased off it dropped back down within a minute or two, and on the downhill the other side it dropped below half way.
Before modifying the gauge I knew nothing of BertieB's hot flushes
but wonder whether he needs a doctor or not.
Chris with BertieB
Post
by Northern Bongolow » Sat Oct 05, 2013 11:11 pm
mine has the same mod, and does about the same----------------sounds fine to me
cmm303
Post
by cmm303 » Sun Oct 06, 2013 8:24 am
Chris with BertieB
Driver+Passengers
Post
by Driver+Passengers » Sun Oct 06, 2013 8:33 am
Mine does the same... also, if I flick the hold button on (drop a gear) while going up a hill, the temperature doesn't rise as much - because revs are higher, the water pump circulates coolant from the engine to the radiator faster, I think. Have a play.
Post
by g8dhe » Sun Oct 06, 2013 11:33 am
Likewise even on a V6 engine.
mikeWalsall
Post
by mikeWalsall » Sun Oct 06, 2013 1:04 pm
Following some advise ..when I modded my temp. gauge I only fitted the resister .. I did not bridge the wire ..
Now when I turn the ignition on the gauge goes up to around one third .. then sits there never moving even after a 'fast' 200 mile journey ..
haydn callow
Post
by haydn callow » Mon Oct 07, 2013 8:37 am
mikeWalsall wrote:Following some advise ..when I modded my temp. gauge I only fitted the resister .. I did not bridge the wire ..
Why?? What does it tell you now and more to the point what will it do if the temp rises......I would think it would be better as standard.
mikeWalsall
Post
by mikeWalsall » Mon Oct 07, 2013 10:36 am
To be honest with just the resister the gauge it does not seem to be fluctuate up or down ..
Reading the fact sheet on doing the mod....
http://www.enginesaver.com.au/Tempgauge.pdfit
... it says to fit an 100ohm resister .. and .. bridge the two wires on the front of the gauge ..
Then some Forum posts said just fit the resister and it would be sufficient / efficient .. so I took this easier route ..!!
haydn callow
Post
by haydn callow » Mon Oct 07, 2013 10:42 am
I think it would be a good thing to do the bypass 'short out' mod....Then your gauge will start telling you things.
Post
by g8dhe » Mon Oct 07, 2013 2:39 pm
Fully agree with Haydn, just changing the resistor will have little affect other than just shifting the normal position a little. I just twisted the Zener diode leads together to short out the diode, the needle will then move without any "pause" in the temperature and the resistor chosen will then adjust the "normal" position to your liking.
the1andonly
- Tribal Elder
Post
by the1andonly » Mon Oct 07, 2013 11:12 pm
Iv'e modified mine with a 100ohm res from maplin as mike w with add mod. It runs on the warm side (2/3 scale) as normal.
when towing uphill (serious hill 1st gear North wales 4 hr trip) it frightened the sh1t out of me hitting the H but at top on going downhill soon temp went down with no load. This is too frightening for me, 110/120 ohm maybe more appropriate.
but at least you can see a change.
or have I got a problem?
teenmal
Post
by teenmal » Tue Oct 08, 2013 12:24 am
the1andonly wrote:Iv'e modified mine with a 100ohm res from maplin as mike w with add mod. It runs on the warm side (2/3 scale) as normal.
This is exactly why these gauges were restricted.
cmm303
Post
by cmm303 » Wed Oct 09, 2013 1:30 pm
exactly my experience but more extreme - my loading was less onerous and have 110 ohm resistor. Hence my post. Love to know the point at which to bail!! Could be relevant for Scotland.
Chris with BertieB
Simon Jones
Post
by Simon Jones » Wed Oct 09, 2013 1:42 pm
The temp gauge (modified or not) just gives you a relative indication of engine temperature. If you want to know when 'hot' is 'too hot' then you'll need a digital display like TM2 / TM4 or even a cheap joby from ebay. While there is no hard and fast temperatures that the engine should normally run at, with an actual read-out you will get to know what the typical values are for your vehicle.
