Stray electrics...
BridportBongo
Stray electrics...
Post by BridportBongo » Sat Sep 28, 2013 3:36 pm
Hi there
I am completely new to Bongos and mostly have let someone else sort my cars out before now, but would like to be able to at least know a bit more about how the Bongo works.
In a general look at the electrics to try to sort out my central locking, I have come across two wires that stop in connectors, and, well, aren't connected.
One is under the glove box, single connection. The other is above / behind fuse box with 4 connectors in one. Wen I have worked out how to put a photo up, I will!
Anyhow, can anyone tell me whether this is normal, or whether they should be plugged in somewhere?
Many thanks for your time
Sam (BridportBongo)
Re: Stray electrics...
Post by Northern Bongolow » Sat Sep 28, 2013 3:43 pm
theres loads of spare plugs/wires all over the bongo mate. it seems the norm.
the 4 wire one behind/around/above the fuse box maybe for front fogs, has yours got them fitted. does your bongo have an A over B switch on the dash, mine has, this is so you can fit driving lights or spots, then switch via the AB switch to spots or front fogs. the spare wires are usually fitted ready down at the front bumper.
