Reversing mirror glass
al & chris
Post by al & chris » Mon Sep 16, 2013 10:11 pm
Just got new glass for reversing mirror. Is it right to replace it you have to heat the casing up to expand. If so I assume you have to take mirror off bongo. Hair dryer or blow torch for heating ?
Simon Jones
Re: Reversing mirror glass
Post by Simon Jones » Mon Sep 16, 2013 10:27 pm
Certainly wouldn't use a blow torch unless you are planning on redesigning it completely :shock:. It's going to be much easier to work on the mirror when it's off the van, but you will need a snug fitting screwdriver as the 4 mounting screws can be tricky to shift. A hair dryer on a low heat setting will probably be ok and it may help to smear some washing up liquid around the rim to make it easier to slide into place.
al & chris
Post by al & chris » Wed Sep 18, 2013 4:20 pm
Thanks Simon removed mirror and fitted today with no problems. Used hair dryer and washing up liquid mirror popped in quite easily.
Brilliant this forum =D> =D> =D>
Simon Jones
Post by Simon Jones » Wed Sep 18, 2013 11:50 pm
Excellent news. Few people tackle that job, so it's good to know it can be done successfully.
