Rear Suspension probs
Pooley
Post by Pooley » Sun Sep 08, 2013 5:58 pm
The rear suspension springs don't seam up for the weight of the vehicle. Every time we go over a bump there's a thud as the rear bottoms out. I've put on some towing spring assisters, but they don't help much. It's as though with the camper van conversion furniture, plus water, cycles on the back the vans springs aren't up to it. Are there stronger springs available? or any other advise gratefully received.
the laird
Re: Rear Suspension probs
Post by the laird » Sun Sep 08, 2013 6:03 pm
Pm jim the box he had exactly the same problems
Hope this helps ,he will ,good guy
the laird
Post by the laird » Sun Sep 08, 2013 6:39 pm
I had "air lifters" fitted to my suspension to stop it bottoming out. Also check you don't have lowering springs, I had them fitted to mine. Measure from the ground to the wheel arches they should be about 30". I would recommend ...
Jim the Box
Post by Jim the Box » Mon Sep 09, 2013 8:44 am
Also check your rear drop-links for wear or damage, are your shocks OK, the air assistors will only function correctly if the existing suspension is up to scratch.
"Today's rain is tomorrow's Whisky"
Pooley
Post by Pooley » Mon Sep 09, 2013 12:12 pm
Thanks for the advice guys.
Is it possible just to get some stronger springs fitted?
I measured road to arch at 29''.
It had been sujested to cut off the rubber buffers, but surely they're there for a reason?
Yours Bumpy!!!
the laird
Post by the laird » Mon Sep 09, 2013 8:20 pm
Definitely do not cut off the bump stops!air bags are you're solution my friend .imop
Post by Northern Bongolow » Mon Sep 09, 2013 8:51 pm
on the back of artic trailers there are (rubber D section rubbers), they use these to stop crap drivers reversing into the loading docks.
i bought a couple of these from a truck part suppliers then made brackets that went through the length of D back to the original holes in the chassis. this gave a softer hit when the suspension reached the top end.
works well after several years of winter log carrying etc. and cheaper than the originals at £40 plus each when the rubbers fall off the back plate.
rita
Post by rita » Tue Sep 10, 2013 9:21 am
Hi Pooly,
I it might be worthwhile contacting someone like this for advice.
http://www.springcoil.co.uk/suspension_springs.html
Pooley
Post by Pooley » Wed Sep 11, 2013 2:00 pm
Thanks again guys, something to work on before we head off to Morocco for the winter!!
salexander
Post by salexander » Thu Sep 12, 2013 10:20 am
Bump stops, improved or otherwise, only control the suspension movement at it's extreme and prevent the suspension from banging off of the chassis. Air lifts will effectively stiffen the suspension, improving the handling at all times and keeping the suspension away from the bump stops for the vast majority of the time, which is as it should be.
