radio and cig lighter not working on 95 bongo
Hi guys and thanks in advance.
My radio and cig lighters aint working after using phone charger.
Can anyone help with pictures etc of what fuse I need to replace.
There is a fuse box under right of the steering wheel. Apart from this where do I go and what do I need to repair.
regards
martin
regards
martin
- helen&tony
Re: radio and cig lighter not working on 95 bongo
No 8 top right in fusebox for starters, also no 1 top Left for radio...
You haven't got a leisure battery, have you?
No 8 15amp,runs cigar lighter/radio/and mirrors.
thanks so much guys
I dont have a leisure battery.
Is it no 1 and 8 fuse or just no.8?
thanks once again guys
It's all in the factsheet here http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
Its the Top Righthand fuse 15 Amp, the top left fuse also powers the radio for backup memories etc.
thanks for advice and i changed the fuse and everything worked. However with coolbox and radio on we were venturing just 2 miles from my home and the bongo just stopped......the ignition ticks over but engine is dead
any advice on electrical problems
That doesn't make much sense!
The ignition ticks over but the engine is dead ? What do you mean ???
What sort of engine is it diesel, v6 or 2l
sorry the display is all lighting up and there is a slight ignition. A mechanic had a look at the timing belt and said it is rotating really fast. Does this help and thanks for response
ta
ta
Take the hassle out of your life, give up smoking and buy an iPod
A Bongo is for life, not just for Christmas
dont smoke elze??? and i doubt an ipod helps. Please dont waste your time posting
Just a little quip, we all have them from time to time. The trick is not to bite, were all in the same boat here!
