tinting windows/removing windows
Moderator: Ian
v8griffith
Post by v8griffith » Thu Jul 11, 2013 9:44 pm
Can anyone advise -
I am wanting to tint my own rear side windows but from experience its far easier done on the bench! so wanting to know if its possible to remove the windows without removing all of the interior panels inside of the van and also wanting to know how the hinge/window locks can be removed from the glass....
any advice welcome
Regards
Ken n Moira
Simon Jones
Re: tinting windows/removing windows
Post by Simon Jones » Thu Jul 11, 2013 11:33 pm
All you have have to do is prise off the covers over the hinges and undo the screws. Be careful not to lose the black 'button' on the outside of the window as that is the nut that holds it in place. The catch mechanism can be removed in much the same way I believe.
This diagram may help: http://lushprojects.com/bongopartsmk2/c ... 1of02.html
v8griffith
Post by v8griffith » Fri Jul 12, 2013 7:32 pm
Thanks for the reply, that's exactly what I wanted to hear... hopefully a simple job then
Cheers Simon
stuc
Post by stuc » Sat Jul 13, 2013 9:57 pm
I did mine, the plastic cover, once clipped off just moves enough to give you clearance to undo the fasteners behind them. Best tip I can give is use good quality tinting film which will shrink with heat, I didn't and it was a right pain in the arse. Used better stuff on the rear screen and it was much better/easier.
Return to “Pimp My Bongo”
