Coolant Alarm won't stop alarming.
spud350
Post by spud350 » Sun Jun 10, 2012 11:47 am
When I turn the ignition on the alarm won't go off. I've checked the screw for corrosion and it's still as new. I've cleaned the contact between the screw and wire terminal but there was hardly any contamination there either. Anymore ideas anyone?
Cheers Spud.
teenmal
Re: Coolant Alarm won't stop alarming.
Post by teenmal » Sun Jun 10, 2012 1:41 pm
Hi Spud,
Does it need a drink :lol:
It sound like a bad connection at the the bullet connector,or the wire has parted company.
Cheers.
haydn callow
Post by haydn callow » Sun Jun 10, 2012 1:57 pm
1st check the level in the tank (2 cms on a dipstick when cold)
Then report back !!
http://www.coolantalarm.co.uk
Also BMW Clocks
spud350
Post by spud350 » Sun Jun 10, 2012 7:37 pm
Water level is fine. I can disconnect and connect at will as it's on a lighter plug. Sometimes it goes off straight away, sometimes it takes 5-10 secs, sometimes not at all. How sensative is it to the voltage supplied to it?
haydn callow
Post by haydn callow » Sun Jun 10, 2012 7:53 pm
it is quite sensitivw,,,,is the lighter socket on the start battery or LB
Also BMW Clocks
spud350
Post by spud350 » Sun Jun 10, 2012 9:55 pm
On the LB now I've fitted my willinton kit.
haydn callow
Post by haydn callow » Mon Jun 11, 2012 7:57 am
That will almost certainly be the problem....As it says in the alarm instructions....connect the positive wire to a IGNITION SWITCHED LIVE..
Also BMW Clocks
rita
Post by rita » Mon Jun 11, 2012 10:11 am
haydn callow wrote:That will almost certainly be the problem....As it says in the alarm instructions....connect the positive wire to a IGNITION SWITCHED LIVE..
Hi Haydn,
Don't understand this bit ((quote When I turn the ignition on the alarm won't go off
jaylee
Post by jaylee » Mon Jun 11, 2012 10:42 am
Hi Spud,
Has this issue only arisen since fitting the Willington LB kit? :arrow:
spud350
Post by spud350 » Mon Jun 11, 2012 10:21 pm
OK just to let peeps know the situation, I have a multi socket ciggy lighter soldered to the back of the drivers ciggy lighter. This gives me 4 things I can run off the 12v (+ a usb) without having to chop into any wires. The things I have running off them are my camera detector, over temp engine thingy, the low level alarm and the drivers one is spare for the sat nav.
The willington now makes them live all the time as they run off the LB. I don't want them live all the time so I put a switch between the back of the ciggy lighter and the multi socket. This just leaves the front one live while the other things only run when I flick the switch.
All worked well for a while but recently when I flick the switch the alarm started playing up by not always going off. I can switch it on and off at will and like I said originally sometimes it works others not. I assumed it was a dirty connection but all that seems OK. Because it didn't do it straight away I don't know whether it being wired to run like this has caused it or it's just coincidence.
I'm wondering how sensitive it is to the voltage as the LB may not be quite as high as the SB but also there will be a little more resistance running through the switch. I assume the alarm activates due to resistance somehow so this could be a possibility. However it worked for a while which is why the confusion. :-k
Cheers Spud.
jaylee
Post by jaylee » Mon Jun 11, 2012 11:42 pm
Try removing the other units except the low coolant alarm & see what happens...?
Is one of the actual sockets on the sockets on the "multi" designated for an actual cigarette lighter perchance?? Sometimes the plug doesn't actually seat right in these after market units...? :idea:
haydn callow
Post by haydn callow » Tue Jun 12, 2012 8:53 am
As I have stongly suggested before...put the coolant alarm on to it's own ignition switched feed.....if not you will be going round in circles forever
Also BMW Clocks
spud350
Post by spud350 » Tue Jun 12, 2012 9:12 pm
jaylee wrote:Try removing the other units except the low coolant alarm & see what happens...?
I know what you mean and I tried that. Didn't make a difference.
Where can I solder onto a main feed. I hate scotch locks with a passion.
Cheers Spud.
bongolou
Post by bongolou » Tue Jun 18, 2013 12:38 pm
haydn callow wrote:As I have stongly suggested before...put the coolant alarm on to it's own ignition switched feed.....if not you will be going round in circles forever
My coolant alarm was fitted by the garage and its powered by a 12v in the cigarette lighter. This is ok but when i need to power the sat nav or phone its not so good. It was a bongo garage that fitted it is this the norm?
2002 Bongo V6 Petrol AFT Sunlight Silver Metallic with YKK awning.
westonwarrior
Post by westonwarrior » Tue Jun 18, 2013 1:18 pm
the top of fuse 8 is controlled by the ignition try connecting it there
