AeroNut
Post
by AeroNut » Mon Jun 17, 2013 12:38 pm
rita wrote:Hi,with automatics you need to check that the brakes are not binding (overheating) does the vehicle freewheel OK.
Is it 4WD or 2WD.
Rita,
I think Mr Walsall thought of that one too. I have had a go at pushing it and yes it does move freely. And it's a V6 2WD.
Just a point, not sure how it works but even when in reverse gear I can push it forward with the motor running! That can't be right!
Regards
Terry D
briwy
Post
by briwy » Mon Jun 17, 2013 4:24 pm
Busted diff?? clutching at straws.
mikeWalsall
Post
by mikeWalsall » Mon Jun 17, 2013 5:15 pm
To my reasoning .. as it has been happening before .. it does seem more of a 'box' associated problem. than a 'final drive' one ..
Did the fluid still look a transparent red .. Or a smelly brown colour .. as that is an indication of burnt clutch (drive) bands ..
Post
by Northern Bongolow » Mon Jun 17, 2013 9:12 pm
are the tickover revs normal, or are they dipping down below normal??.
AeroNut
Post
by AeroNut » Tue Jun 18, 2013 7:25 am
mikeWalsall wrote:To my reasoning .. as it has been happening before .. it does seem more of a 'box' associated problem. than a 'final drive' one ..
I had the oil changed a matter of 6weeks ago. This included having the sump taken off and cleaned? (I even sourced a new sump gasket from JPN) I asked them to clean the Labarinth filter and so on. My thoughts are something may of been disturbed and now somethings blocked....?
To answer the question the oil is extremely transparent and not burnt...
TJD
AeroNut
Post
by AeroNut » Tue Jun 18, 2013 7:27 am
Northern Bongolow wrote:are the tickover revs normal, or are they dipping down below normal??.
That's the strange bit, the engine ticks over normally and if I engage the drive the revs drop around 100rpm as if it's in gear... just got no drive....?
TJD
Post
by mikeonb4c » Tue Jun 18, 2013 8:50 am
AeroNut wrote:mikeWalsall wrote:To my reasoning .. as it has been happening before .. it does seem more of a 'box' associated problem. than a 'final drive' one ..
TJD
Given that you've said the gearbox had been making noises for a while, assuming this was after the fluid change, then there does seem to be the possibility of a connection. Was the job done by a Bongo expert, autotransmission expert? I think you need to be talking with the latter (try PMing Alacrity in case he still reads posts). Impossible to say, but I wonder if the box is fundamentally ok but something - solenoid pack maybe - is playing up. Good luck, keep us posted.
AeroNut
Post
by AeroNut » Tue Jun 18, 2013 12:20 pm
I'm of a similar opinion that somethings gone wrong down below....
Possibly blocked solenoids leading to failed oil feeds hence strange noises especially whilst cold....
Your question was it done by an expert..... they thought so?
Has it been done by an auto expert... they think so?
My opinion ....****
Given what else the did when servicing and charged me for ..... No! sadly.
Now it's a case of what to do next....
I'm going to take a look around the outside tomorrow morning, if the rain holds off. try and clean up any electrical connections that I can find.... look for leaks?... look at sourcing another gearbox if one can be found near enough...
Question, are all bongo gearboxes the same?
2wd ...
I have a 2001 V6
I will source another, fix the one I have and either sell it on or swap back into my van and keep one as a spare.... Where can I find another????
Thanks for you help so far people....
Regards
Terry D
helen&tony
Post
by helen&tony » Tue Jun 18, 2013 12:41 pm
This chap comes highly recommended, and I've had odd bits from him
Here'a a box:
http://www.ebay.co.uk/itm/Mazda-Bongo-F ... 3a81ef0966
Give him a tinkle
Post
by mikeonb4c » Tue Jun 18, 2013 2:14 pm
I wonder if boxes are different internally, to provide the right gear ratios for each different type of engine and its torque/power curve? Have you tried PMing Alacrity yet? Good luck
briwy
Post
by briwy » Tue Jun 18, 2013 4:15 pm
I'm inclined to agree, it sounds like something in the box but have look and see if the propshaft is going round when it's in gear with the the engine running.
If it is then I guess the diff is knackered or something is slipping inside the box.
Were there any nasty bits in the gearbox sump when they changed the oil?
AeroNut
Post
by AeroNut » Tue Jun 18, 2013 7:08 pm
Unfortunately letting someone else do the work I wasn't privie to what was seen and done, only what they told me.
Regards
TJD
AeroNut
Post
by AeroNut » Sun Jun 23, 2013 6:04 am
looking at what S/H gearboxes are around... I'm being asked to quote a number on plate on the box? can't obviously see one... Anyone suggest where it might be, or is this number quoted anywhere else? thanks
TJD
helen&tony
Post
by helen&tony » Sun Jun 23, 2013 8:39 am
Can you trace it from the VIN number on the passenger B pillar (rear of door opening)....I would suspect there is a given type of boxe for every production run of vehicles, and you should be able to tell the exact manufactured date if you put your VIN number in the Russian Bongo site
teenmal
Post
by teenmal » Sun Jun 23, 2013 12:05 pm
AeroNut wrote:looking at what S/H gearboxes are around... I'm being asked to quote a number on plate on the box? can't obviously see one... Anyone suggest where it might be, or is this number quoted anywhere else? thanks
TJD
Hi,Re the plate it would be worthwhile asking the person that is supplying the S/H box where you can find it.
If the Part Number is of any use to them its......BW1719090
