Engine whine
al & chris
Engine whine
Post by al & chris » Wed May 29, 2013 4:08 pm
Our bongo has developed a whine which only seams to be there at tick over. As soon as engine is revved it disappears. Sounds like it is coming from passenger side but not sure where. At first thought it might be alternator or turbo but not sure now. Looks like I might also be loosing a bit of oil. Performance of van seems fine no smoke so looks like oil loss is from a leak.
Re: Engine whine
Post by mikeonb4c » Wed May 29, 2013 7:56 pm
Just make sure it isn't autobox transmission fluid. Someone put me onto an excellent garage in new mills that knows Bongos. Maybe get it looked over?
al & chris
Re: Engine whine
Post by al & chris » Wed May 29, 2013 8:05 pm
Checked autobox levels all ok
Re: Engine whine
Post by Northern Bongolow » Wed May 29, 2013 8:26 pm
in the link below, look at the tensioner pulley for the air con. you can take the belt off to see if the noise stops the bearing usually makes a racket, strip and clean/oil sometimes works, but others have replaced it from local bearing suppliers.
wonkanoby
Re: Engine whine
Post by wonkanoby » Thu May 30, 2013 7:58 am
i got a bearing repair kit from a mazda dealer
al & chris
Re: Engine whine
Post by al & chris » Sat Aug 03, 2013 11:26 am
Just had van serviced and all that noise was coming from a blocked engine breather. :D :D not an expensive job.
Re: Engine whine
Post by Bob » Sat Aug 03, 2013 4:54 pm
Bingo. =D>
the laird
Re: Engine whine
Post by the laird » Sat Aug 03, 2013 4:59 pm
Bongo :D [-o<
Simon Jones
Re: Engine whine
Post by Simon Jones » Sat Aug 03, 2013 6:53 pm
Get a trigger spray bottle filled with water and (carefully) squirt it over the 3 belts while the engine is running. If the noise changes or goes away then it's a noisy / loose / tight belt.
teenmal
Re: Engine whine
Post by teenmal » Sat Aug 03, 2013 6:59 pm
Simon Jones wrote:Get a trigger spray bottle filled with water and (carefully) squirt it over the 3 belts while the engine is running. If the noise changes or goes away then it's a noisy / loose / tight belt.
Yer a wee bit late.
:lol: :lol:
Simon Jones
Re: Engine whine
Post by Simon Jones » Sat Aug 03, 2013 10:13 pm
Well, it might come in useful for next time :D.
