front heater problem
Re: front heater problem
Post by Northern Bongolow » Wed Mar 27, 2013 11:53 pm
front of the engine mate.
the edge can be seen at the passy side if you lift the seat. the problem is that the lower edge is hidden by the crankshaft pulley, so when it leaks out of the (telltale) hole at the 6 oclock position it goes undetected.
you need a dentist angle head mirror to see it.
Post by mikeonb4c » Thu Mar 28, 2013 9:22 am
mikeonb4c wrote:Try squeezing your top hose. If it is hard and feels crunchy.......you have a crud problem :shock:
Out of interest, did you try the crunch test?
gartland
Post by gartland » Thu Mar 28, 2013 10:36 am
yes tried the crunch test .hose easy to squeeze .now going to search for the pump
wonkanoby
Post by wonkanoby » Thu Mar 28, 2013 10:50 am
Follow the 2 belts on the alternator back to the engine
teenmal
Post by teenmal » Thu Mar 28, 2013 10:58 am
gartland wrote:where is the waterpump situated #-o :?
Hi,what vehicle do you have.
gartland
Post by gartland » Thu Mar 28, 2013 11:19 am
1995 2.5 DIESEL
wonkanoby
Post by wonkanoby » Thu Mar 28, 2013 11:34 am
lift drivers seat and dop as above
Simon Jones
Post by Simon Jones » Thu Mar 28, 2013 11:38 am
Diagram of cooling system components: http://lushprojects.com/bongopartsmk2/c ... 2of02.html
teenmal
Post by teenmal » Thu Mar 28, 2013 11:45 am
gartland wrote:1995 2.5 DIESEL
OK,if you stop the video at the front of the engine,the water pump(aluminium coloured) is above the crankshaft pulley(the big black thing at the bottom of the pic)It shows the water pump without the belts or pulley.
Good Luck..
http://www.youtube.com/watch?v=hMJQaN_8HGc
