2.0l Petrol Heater
psquiddy
2.0l Petrol Heater
Post by psquiddy » Sun Mar 24, 2013 7:50 pm
I have posted previously about my temperature gauge (it seems to run cold if over 40mph - if stuck in traffic it registers ok)
However - this does affect the heating - if running at a decent speed the heater is like a glow worm, if I am stuck in traffic it gets nive and warm.
Any suggestions - it was just a bit too cold today and no I dont want to spend every winter in a traffic jam.
Over 300 free things to do in London
http://www.toplondondaysout.co.uk
Re: 2.0l Petrol Heater
Post by g8dhe » Sun Mar 24, 2013 7:56 pm
Are you certain that there is a thermostat in the housing ? I wonder if it could have been removed? Normally done on the diesel to stop overheating whilst its sold :-( But you never know, could even be a failed thermostat stuck open maybe ?
Simon Jones
Post by Simon Jones » Sun Mar 24, 2013 9:57 pm
If you've got a post '99 van, check if the summer / winter flap for the heater is set appropriately otherwise you're sucking in too much cold air. See part labelled A in this diagram.
The other thing, have you pressed the recirculating button on the control panel as again, it will reduce the external air flow so you're re-heating already warm air.
psquiddy
Post by psquiddy » Tue Mar 26, 2013 7:39 pm
Simon
You seem to have been spot on - moved the lever under the bonnet and went for a short drive - I was getting warmth after 2 miles, lovely.
Thanks.
Simon Jones
Post by Simon Jones » Tue Mar 26, 2013 8:07 pm
Excellent news :D.
