heater
Baz and Helen
heater
Post by Baz and Helen » Wed Mar 20, 2013 7:29 pm
Hi we are having a problem with the heater still, we have had new radiator , new pipes, new thermostat, bled the system, we found out the rear heater has been blocked off but we dont get any heat in the front thanks for your help. Baz and Helen
windywatson
Re: heater
Post by windywatson » Wed Mar 20, 2013 9:32 pm
If the engine is getting up to temprature, and as you have done all of the work that you have listed I would suggest that you take a good look at the flaps that the heating controls operate. There are small acctuators that are electrically operated that open/close flaps dependent on the settings. If you have a look in the foot wells on drivers & passenger sides center of the consol near the floor you will see the small circular accuators and the flaps they attach to. You should be able to see these operate when you adjust the settings.
If you use the search facility ( scroll down whilst in this field and find search bottom left )on this forum, you will find a lot of threads covering heater problems. Plus now you have placed this question here on the forum many more members will follow with many more suggestions & helpful information.
Place your location in your avitar and some one local may be able to pay you a visit to help.
Cheers & luck with resolving your problem.
Windy-Watson
2001 V6 Tin Top
Baz and Helen
Re: heater
Post by Baz and Helen » Wed Mar 20, 2013 10:46 pm
Hi thanks for your help will check that out tomorrow and let you know
Simon Jones
Re: heater
Post by Simon Jones » Thu Mar 21, 2013 12:38 am
Have you got manual or digital controls? The manual version moves the flaps with cables while the digital one uses motors. Either way, stick your head under the centre of the dashboard while your glamourous assistant fiddles with your knobs / buttons :). Hopefully you'll see things moving as the flaps do their stuff.
Is the fan itself working correctly on all the fan speed settings?
wonkanoby
Re: heater
Post by wonkanoby » Thu Mar 21, 2013 9:03 am
There are 2 hoses feed the heater through the bulkhead
are they both hot
if only one is heater rad may need flushing of crud
