How to remove rear ac unit and heater to make space
Moderator: Doone
BILLFACE
Hi everyone just stripping out my bongo and trying to work out how to remove rear ac and heater any advice would be great. I need to free up space for fridge and water tank.
Re: How to remove rear ac unit and heater to make space
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29530.
this will help a little.
disregard the title, it does get interesting
Last edited by Northern Bongolow on Thu Mar 22, 2012 6:15 am, edited 1 time in total.
top tip - thanks for the link.
Removed mine in preparation for fitting Eberspacher heater. There is a lot of space you can make use of once all the gubbins are out the way:
Blanking the A/C by cutting the pipe, crimping the end & brazing it closed with aluminium rod:
Bypassing the cooling system:
New Forest Terrier
Probably asking the absolute obvious, but will the rear air conditioning work after the rear heater has been taken out of the coolant circuit following a leak. I never use it, the front is enough or if really hot I open the sun roof. I had a drenched passenger on Sunday who wondered if it would help drying out soggy football kit and I just turned the front heater up which did the job.
I cannot think of a connection on the rear air conditioning which would require water, but am I missing something?
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
Rear A/C should work fine for cold air even with no coolant flowing.
- helen&tony
Yes...rear aircon works when by-passing or removing the heater matrix...I've been running like that for a couple of years. I shall remove the whole box in the warm weather and replace the matrix with an all-metal one I have in stock!!!! The old matrix suddenly lost the plastic stubs with no warning...LCA screamed, and I stopped within 100 yards...and only 7 Klix from home, so not even warm!!!!!!
If reconditioning the whole cooling system, it's REALLY worth while swapping the matrix for a metal one...I've taken a matrix to pieces, and the old stubs go almost crystalline with age!!!!
