Fuel pump seals replacement
lazyb5
Post by lazyb5 » Sat Mar 02, 2013 12:59 pm
Just finished replacing the seals...successfully. A great big thank you to whoever created the fact sheet in the members area. A couple of things that helped me that weren't in the fact sheet.
If you loosen the solenoid plate the double fuel pipe will swing towards the engine and help get your hand round the back of the pump. As the fact sheet says loosen front cover first, i left mine hanging from the bolts, it also releases the spring pressure. At the back of the pump work on the bolt furthest away ie closest to front of car first as the other bolt obstructs your hand. Have a magnetic pick thingy, the thing like an aerial that has a mag at the end mine also has a light it allows you to undo bolts and just catch them. Grease your right wrist, back of your hand and base of your thumb to help your hand slide between pump and air intake, I used vaseline :shock: :lol:. Use your mirror to check you have the rear seal in correctly. When replacing rear plate put furthest bolt through the plate and lower in from the top using your magnet. Use your right hand behind the pump to guide into position, this is really difficult I tried about 5 times before I managed. Once the back is done have a cuppa you've earns it.
Titan1995
Re: Fuel pump seals replacement
Post by Titan1995 » Sat Mar 02, 2013 4:04 pm
You were lucky if just the side seals were leaking.
I removed the pump and had all of mine replaced at a local Bosch dealer..
lazyb5
Post by lazyb5 » Sat Mar 02, 2013 5:58 pm
Looks like I was lucky then, I've always got the rest of the kit in case anything else leaks
Post by Northern Bongolow » Sat Mar 02, 2013 9:41 pm
just did mine last weekend, i was surprised at the difference it has made.
my wrist and knuckles are healing up nicely, how are yours doing :shock: :lol:
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Sat Mar 02, 2013 9:50 pm
Nice one LB5 happy bongoing 8)
lazyb5
Post by lazyb5 » Sat Mar 02, 2013 10:47 pm
Hi Ady, Vaseline is the answer :shock: Rear anti roll bar repaint and new rubbers/drop links tomorrow.
Hi M8ONGO there's always something to do, can you drop the name and address of the guy for the arches ,they will need doing shortly. After that I'm just going to enjoy driving the bloody thing :lol:
M 80NGO
Post by M 80NGO » Sun Mar 03, 2013 12:54 am
That'll be Martin Jackson at Huntingdon coachworks, warboys airfield ind est PE28 2SH, 01487 824808.
lazyb5
Post by lazyb5 » Sun Mar 03, 2013 4:50 pm
Thanks mate I'll put it in the address book...sadly I will need his services bloody salt.
Titan1995
Post by Titan1995 » Sun Mar 03, 2013 11:41 pm
Side seals not a headache.....the rear manifold is a different ball game.
