rear heater
Baz and Helen
- Bongonaut
rear heater
Hi again, I wonder if anyone can help, we had to replace the radiator weve bled the system but the rear heater wont get warm. the rear heater has never worked since weve had the van. Im wondering what else we can check. many thanks Baz znd Helen
Re: rear heater
could be a air lock , or it might not ven be connected anymore some people bypass them if they get a leak or it could even be blocked up
- Driver+Passengers
Re: rear heater
Pop your head under, just behind the driver's door and look up. You should see either 0, 2 or 4 pipes disappearing up through into where the rear heater and aircon sits.
The two fore-most are coolant, the two rear-most are smaller bore and aircon.
Tell us what you see, or take a pic if you're able.
Matt.
Matt.
Baz and Helen
- Bongonaut
Re: rear heater
Hi Matt have looked underneath there are only 2 pipes, which I presume are air con pipes.
- Driver+Passengers
Re: rear heater
OK, sounds like the rear-heater has been disconnected, explaining why you can't get it to go hot.
If you have another look, a little bit forward from there and in a bit, you should be able to identify a couple of metal pipes hanging down on brackets - one going forwards along under the driver and one going round the back of the engine. One of them might be a T-junction iirc - my memory of the layout of all this is a bit hazy... You should either see that they have been blanked off, or connected together. If the latter, it will either be a single rubber hose, or perhaps two joined together in the middle somehow.
It's all a bit academic working out what work was done - but you should easily be able to determine which of the above it is, just to confirm.
And that's it - you can leave it there, I think.
Unless you want to reintroduce the rear heater... at which point you should somehow pressure test it before connecting it up.
Re: rear heater
This is what you might see if it's been bypassed:
Baz and Helen
- Bongonaut
Re: rear heater
thanks for all your help will check it out tomorrow
Re: rear heater
I cheated and cut a small square out around where the rear heater pipes drop tho the floor than cut the bottom out of the heater box to draw the rad out,replaced rad, glued the heater box bottom on then re-fitted the square with a new piece of tin,re-undersealed and now i heat in the rear!!! happy children..
mark
mark
