Is this the same as the ATF fluid used in the gearbox?
Can't find any info on it in the tech sheets on the members pages, or by searching
Is there a recommended changing period ( either based on time or mileage) as with gearbox fluid and brake fluid ?
I've just done the gearbox & have some ATF fluid spare, so looking at changing the steering fluid if it's compatable
Thanks in advance
ChrisQ
power steering fluid
- mikeWalsall
Re: power steering fluid
Same fluid as in the auto box (I use Dexon3) .. just 'pull' out the old fluid from the power steering with a syringe .. old bike pump or syphon it out ..
Thanks for the confirmation.
Yes its Dexron 3 that I've got. Handy hint regarding syringe, as I have a 50ml one
ChrisQ
ChrisQ
