Fluorescent cabin light being dim when engine off
Jimbob1979
Post by Jimbob1979 » Thu Feb 14, 2013 9:17 pm
Has anyone experienced a problem with the fluorescent cabin light being dim unless the engine is running. The battery seems fine. Starts no problem and it is showng 12.5v on a multimeter. I tries cleaning the earth connection to the chassis but this has made no difference.
Jim
Simon Jones
Re: Fluorescent cabin light being dim when engine off
Post by Simon Jones » Thu Feb 14, 2013 9:54 pm
Fluorescent bulbs do tend to get progressively more dim with age, so you may just need to source a replacement or find another Bongo owner who you can try swapping with to verify if it's the bulb or the fitting.
Jimbob1979
Post by Jimbob1979 » Thu Feb 14, 2013 10:00 pm
It seems odd that it would be perfectly bright when the engine was running if it was the bulb.
westonwarrior
Post by westonwarrior » Thu Feb 14, 2013 10:13 pm
strange things those bulbs,
they drain batterys when off if faulty too
they can be replaced for a couple of £ so give it a go
Jimbob1979
Post by Jimbob1979 » Thu Feb 14, 2013 10:21 pm
Thanks for your repleis, i'll get one orderd.
Post by g8dhe » Fri Feb 15, 2013 12:01 am
Have you removed the tube and replaced it, might just be be the tube contacts, also check the switch contacts make sure they are clean.
Velocette
Post by Velocette » Fri Feb 15, 2013 11:42 am
Probably the tube. I carry a spare you can try if you are in Bristol, you don't say where you are. They are about £2 from RS Components.
Jimbob1979
Post by Jimbob1979 » Fri Feb 15, 2013 1:26 pm
Thanks. I bought one from Bongo Fury in the end for £5 so i'll see if it does the trick
Post by Ian » Fri Feb 15, 2013 4:26 pm
Jimbob1979 wrote:Thanks. I bought one from Bongo Fury in the end for £5 so i'll see if it does the trick
It's on its way. And for those of you thinking, "that's a bit steep", blame Royal Mail. Their minimum charge for a small stuffed envelope is £2.70!!!!
Jimbob1979
Post by Jimbob1979 » Wed Feb 20, 2013 7:03 pm
Thanks all, new bulb arrived today and seems to have done the trick. Must have been on it's last legs.
