	Moderator: Ian
								stuc
						Post
								by stuc » Sat Feb 02, 2013 10:40 pm
								M 80NGO
						Post
								by M 80NGO » Sat Feb 02, 2013 10:46 pm
			Lookin good, I love led's
								the laird
						Post
								by the laird » Sat Feb 02, 2013 11:13 pm
			Stuc hi the laird here can I ask you where about you got the storage boxes under the seat
Bongo pimps looking good
								stuc
						Post
								by stuc » Sat Feb 02, 2013 11:15 pm
			They were already in the van, but I'm sure the lad said Asda. They fit well, just need to angle them a bit when you slide them out.
								the laird
						Post
								by the laird » Sat Feb 02, 2013 11:25 pm
			Cheers stuc will pop in the morn
Never noticed them in Sadat b4
Don't know if your interested but got a good wee clock /inside and outside temp unit at lidl fora four pounds
								stuc
						Post
								by stuc » Sat Feb 02, 2013 11:47 pm
			Got one last time will have a look, cheers
								Mickymouse
						Post
								by Mickymouse » Sun Feb 03, 2013 12:27 pm
			I like the led's,how are they wired up? Also,what is the green light in the roof lining?
									White 1996 P.reg SGL3 2.5D AFT Side Conversion
								stuc
						Post
								by stuc » Sun Feb 03, 2013 10:12 pm
			The rear one is just wired up straight to the interior light up in the back left hand corner. Very easy just check with a meter which ones live with the light on. The side door wired into a constant live from the leisure battery and to the door switch for the side door also very easy. The green light in the head lining is a switch to power the dvd unit. Probably doesnt need it but it is handy just to switch it off completely.
								daveblueozzie
						Post
								by daveblueozzie » Sun Feb 03, 2013 10:49 pm
			Your on the long slippery slide to forever pimping
Looking good my friend,
									Lost without my Bongo.
								stuc
						Post
								by stuc » Sun Feb 03, 2013 11:03 pm
			Thought you'd be along shortly Dave, as soon as LED was mentioned. I take all my inspiration from you. I wouldnt of started if I hadn't seen your van at Silverdale. Is that meet still on? never saw it advertised last year. Or was I not invited back. Promise I won't turn up with broccoli again.
