Cooling system pressure test kit anyone? DO NOT DELETE
Re: Cooling pressure test kit anyone?
he uses the 2 systems, the pressure test to test the system and the vacuum to refill
Happiness isn't having what you want its wanting what you have.
How does that work when you need the stat to open? shoot me if im thick!
- Driver+Passengers
Re: Cooling system pressure test kit anyone?
DO NOT DELETE?
Edit: Sorted
Edit: Sorted
excellent post, u could not have made it any easier.....
V6 2.5i Tintop Aero Petrol/LPG
- Toby&Jules
- Bongonaut
Re: Cooling system pressure test kit anyone? DO NOT DELETE
Indeed. Ours is still hibernating, but the more I read, the more paranoid I get about leaks. I just want Bongo ownership to be a happy experience for us both. Definitely gonna be doing this shortly.
Regards
Toby
Regards
Toby
a spin on this tester is to put the gauge in line and use a flat cap to test.
put the gauge on a t piece, then put half the pipe on either side of the t piece, then get a standard cap and remove the seal, this gives easier pressure readings.
when your happy with it you could fit it to the end of the bleed pipe, then put the gauge in the cab, then you have constant pressure monitoring.
- Driver+Passengers
What, so you look like Fred Dibnah while doing it?Northern Bongolow wrote:a spin on this tester is to put the gauge in line and use a flat cap to test.
some would say i dont need the cap to do that matt.
ps. have you got a light for this woodbine
