WING MIRROR
- Bongonaut
WING MIRROR
Hi we are very new to camping and Bongos. I wonder if any one can tell us how to tighten up the wing mirror as its quite loose. many thanks. Baz and HELEN
Re: WING MIRROR
Welcome to the forum!
If they're the electric folding mirrors then they may just have popped out of position, in which case pull them open and then cycle the mechanism a couple of times and after a bit of clicking they will re-engage. If its the mirror itself within the case then it might be that they have jumped out of the clip but that is usually obvious and just need pressing firmly back into position. Other than that I guess the three bolts holding the entire mirror assembly might be loose, but not heard of that before!
Re: WING MIRROR
Might be a broken tooth on the retracting cog? seen that before and leaves a little wobble on the whole unit? as Geoff says, unit comes off quite easily worst case scenario
Julian
Julian
- Bongonaut
Re: WING MIRROR
Thanks Geoff and Julian for your help. Will try it tomorrow when we have dug it out of the snow. Many thanks Baz and Helen
