code 22?
Re: code 22?
What engine?
Re: code 22?
If you're doing it the conventional way, then 22 is not listed. This is the only website I've come across that explains the diagnostic codes: http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
In addtion to what engine type you have, it would be helpful if you tell us what the symptoms are
. The engines fitted to Bongos are a pretty ancient design, so won't have modern OBDII fault codes.
- Junior Bongonaut
Re: code 22?
Simon Jones wrote:If you're doing it the conventional way, then 22 is not listed. This is the only website I've come across that explains the diagnostic codes: http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
In addtion to what engine type you have, it would be helpful if you tell us what the symptoms are. The engines fitted to Bongos are a pretty ancient design, so won't have modern OBDII fault codes.
Engine turns over - will not start - no power getting to stop solonoid. Glow plug relay flashes indicating engine fault, garage says fault 22?
Engine 2.5 turbo diesel, 2001 flybywire
- Junior Bongonaut
Re: code 22?
francophile1947 wrote:What engine?
Re: code 22?
Do you know how they've concluded it's code 22? There's some more diagnostic info here, but again 22 isn't listed: http://www.igmaynard.co.uk/bongo/member ... ostics.pdf
- Junior Bongonaut
Re: code 22?
Thanks really appreciate info - will speak garage again on Monday.Simon Jones wrote:Do you know how they've concluded it's code 22? There's some more diagnostic info here, but again 22 isn't listed: http://www.igmaynard.co.uk/bongo/member ... ostics.pdf
Cheers Neil
Re: code 22?
Does the glow plug light flash as soon as the ignition is turned on? check the internal fusebox, centre row far left? 15A.
Does the car have an alarm or immobiliser fitted?
Julian
Julian
