Ball joint rubbers cracked within 3 weeks
Driver+Passengers
Post by Driver+Passengers » Mon Nov 19, 2012 7:39 pm
Poor show. :(
Image Image
Re: Ball joint rubbers cracked within 3 weeks
Post by Northern Bongolow » Mon Nov 19, 2012 7:43 pm
who's were they, or if you dont want to slag em off, were they mazda ones.
Driver+Passengers
Post by Driver+Passengers » Mon Nov 19, 2012 7:43 pm
They were not the cheapest available. They were not genuine Mazda.
Can you fit a ball joint incorrectly?
PS. Both are cracked.
Image Image
Post by Northern Bongolow » Mon Nov 19, 2012 7:49 pm
no #-o
Driver+Passengers
Post by Driver+Passengers » Mon Nov 19, 2012 9:04 pm
Image Image
Diplomat
Post by Diplomat » Mon Nov 19, 2012 9:09 pm
Thanks for the warning.
I will have to rethink my policy of starting my pre- MoT work four weeks before submitting it!
Frank
They flew, I took up naturism
Simon Jones
Post by Simon Jones » Tue Nov 20, 2012 12:46 am
Yikes - they look like they've had 3 years use not 3 weeks. I'd say you have very good grounds for requesting a full refund from the supplier as they are clearly not fit for purpose.
Post by Northern Bongolow » Tue Nov 20, 2012 9:53 pm
:shock: :shock: :shock: :shock: :shock: :shock: :shock:
lazyb5
Post by lazyb5 » Tue Nov 20, 2012 10:14 pm
Jeepers they looked like mine after god knows how many years, on the positive side is quite easy to replace rubbers now we know mazda do them, the lead I was following turned out to be a dead end and pointless :(
Driver+Passengers
Post by Driver+Passengers » Tue Nov 20, 2012 11:33 pm
Warranty replacement pair to be sent out tomorrow. I'll go with a full replacement this time and perhaps just rubbers if there's a next. It's a little extra hassle to drop the entire wishbone and get them pressed out and in, might cost me a tenner or two...
Image Image
lazyb5
Post by lazyb5 » Tue Nov 20, 2012 11:36 pm
I'd be tempted to just do rubbers and keep the balljoints in case you need them. No pressing required. :D
Driver+Passengers
Post by Driver+Passengers » Tue Nov 20, 2012 11:40 pm
I'm hearing a crick from somewhere when I list. I don't know if it's the balljoints, but if I'm being sent a brand new pair under warranty, then they're going to go in as-is.
Image Image
lazyb5
Post by lazyb5 » Wed Nov 21, 2012 12:43 am
Did you grease your wishbone rubbers and only tighten them up when the van was on the ground other than that drop links roll bar brackets then balljoints....I think balljoints seem to last the longest of all things
Post by Northern Bongolow » Wed Nov 21, 2012 9:14 pm
lazyb5 wrote:Jeepers they looked like mine after god knows how many years, on the positive side is quite easy to replace rubbers now we know mazda do them, the lead I was following turned out to be a dead end and pointless :(
good effort anyway. =D> =D> =D>
Driver+Passengers
Post by Driver+Passengers » Wed Nov 21, 2012 9:21 pm
lazyb5 wrote:Did you grease your wishbone rubbers and only tighten them up when the van was on the ground other than that drop links roll bar brackets then balljoints....I think balljoints seem to last the longest of all things
Yep, did that. Might be inner ball joints on the steering...
Image Image
