Bongo won't engage gear
cavey
Post by cavey » Thu Nov 01, 2012 12:22 pm
Hi fellow Bongo people.
We have a gearbox problem. I first experienced the problem a few months ago when reversing at full lock, fully laden, but it has been fine up until a couple of days ago. Now, when cold, there is no drive at all, in any of the gear lever positions - the engine just spins up. When warm, I can just about get enough drive to move, but the engine has to rev quite high for this to happen. A couple of days ago, the problem was there, but not as bad and it just seemed that the 'box wouldn't lock into top gear.
Does the transmission fluid need replacing? Being second hand, I don't know when it was last done.
Any thoughts or similar experiences?
Thanks, Dave.
umbongocat
Re: Bongo won't engage gear
Post by umbongocat » Thu Nov 01, 2012 12:30 pm
We had a similar problem on a European trip. Ours is back in the UK now and was a clutch in the gearbox. We couldn't get it into reverse, it was like it was in park. Thankfully, it's being fixed now and should have her back shortly. I'm sure other peeps will be on here soon to help.
Good luck
I love cheese!
Post by g8dhe » Thu Nov 01, 2012 1:47 pm
Have you checked the level of the ATF ? Its a dip stick under the drivers seat, but needs to be done when warm and in gear so take relevant precautions!
cavey
Post by cavey » Thu Nov 01, 2012 1:48 pm
g8dhe wrote:Have you checked the level of the ATF ? Its a dip stick under the drivers seat, but needs to be done when warm and in gear so take relevant precautions!
Nope - the first job when I get home from work..... Thanks!
Simon Jones
Post by Simon Jones » Thu Nov 01, 2012 1:50 pm
At least check the level & condition of the ATF. There is a factsheet here: http://www.igmaynard.co.uk/bongo/member ... ts/atf.pdf
May be worth changing the fluid anyway as it cannot make the problem any worse.
cavey
Post by cavey » Thu Nov 01, 2012 1:59 pm
Is this stuff suitable? http://www.halfords.com/webapp/wcs/stor ... yId_255219
Thanks again. Dave
321Away
Post by 321Away » Thu Nov 01, 2012 2:10 pm
yep that'll do,says meets D(dexron)3 spec
Julian
wonkanoby
Post by wonkanoby » Thu Nov 01, 2012 4:43 pm
Drop the sump and filter and clean the crap out
you will be amazed how much there is
a pela pump makes it easier
as oil should be above gasket level
but you can do it without
cavey
Post by cavey » Thu Nov 01, 2012 11:14 pm
It's a rusty pipe that's leaking. I topped up the ATF fluid and it drove OK, but looking underneath and I saw this.....
https://www.dropbox.com/s/gnnbr4ihnsko3nh/IMG_0959.jpg
The leak stopped when the engine stopped.
It looks like 199A0 on this drawing but am happy to be corrected!
http://lushprojects.com/bongopartsmk2/c ... o=.html#28
Where's the best place to buy a replacement from and are they simple enough to change? I can't see them in the Bongo Fury shop.
Cheers,
Dave
Simon Jones
Post by Simon Jones » Fri Nov 02, 2012 1:05 am
You can order most items from your local Mazda dealer, although it may take a few days up to a couple of weeks for it to arrive. I'm not aware of anyone who would have a new one in stock.
You could try repairing it, or source a used part. Depends where in Hants you are, but I would recommend Kevin at Southern Bongos between North Baddesley and Chandlers Ford. His number is 02380 733995 / 07860 612360 and he has a few vans in for breaking at the moment.
lazyb5
Post by lazyb5 » Fri Nov 02, 2012 1:34 am
Well at least your know what the problem is. Have you checked the joint or the clip. To get you going in an emergency you can connect the cooler hoses together bypass the leak.and cooler :( and drive a few miles but don't overdo it and try to get into lock up wherever possible.
cavey
Post by cavey » Fri Nov 02, 2012 8:04 pm
Thanks all. Have spoken to Kevin today (he is at most 10 mins away!) so will pop in tomorrow and see if he has the pipe in stock.
Post by Northern Bongolow » Fri Nov 02, 2012 10:35 pm
just replaced these pipes on a bongo recently. the owner bought the pipes from mazda, they were not that expensive.
read this one.
http://www.igmaynard.co.uk/bongo/forum/ ... 78#p571797
cavey
Re: Bongo won't engage gear - sorted.......for now......
Post by cavey » Sat Nov 03, 2012 9:18 pm
OK, so it was a pin prick leak which I couldn't even make out, even after a degrease and rub down with abrasive. The pipe actually looked quite solid underneath - not the rusty mess I was expecting.
To get me back on the road, I've used Chemical Metal, and this seems to have done the trick. I feel that I should still replace the pipe as soon as is practical though, as know it's gone once, it may go somewhere else.
After this, it took 2l of ATF to top it up :shock: :!:
I'll be popping in to Southern Bongos on Monday to see what Kevin has in stock.
Cheers all for you help and suggestions! :D
Dave.
