front axle bearing
front axle bearing
wonder if anyone in the forum has a picture and could post it on the forum of the front axle with the offside inner cv joint removed showing presumably a bearing and the means that it is retained in the end of the axle tube have a bearing at this point with a large amount of play
Re: front axle bearing
Hi Stevo,
I have got the same issue havent got round to doing it yet my van is off the road undergoing bodywork restoration didnt get much response from the part images I have seen there is a bearing in the end of the tube retained with a large circlip see the part 27-145
http://lushprojects.com/bongopartsmk2/c ... o=.html#11
http://www.igmaynard.co.uk/bongo/forum/ ... 94#p560767
Stuart
Stuart
1995 Ford Freda 2.5 TD 4x4 AFT
thanks coradia63 getting a better idea of the componentry looking at links in your post gonna be either the bearing or the splines on the components next will be to establish procedure of dismantling and rebuilding thanks again
