Service hole cover
Service hole cover
What is the 'service hole cover' referred to in the fact sheets about coolant replacement?
'Enjoy every sandwich'
- Driver+Passengers
Re: Service hole cover
Haven't been out to check, but is there not a flappy bit of plastic under the duct, above the radiators?
Hi TerryG,
I would imagine the service hole cover would be the engine cover (the seats etc)
Cheers.
Cheers.
rita wrote:Hi TerryG,
Cheers.
I wondered if that was what it referred to.
Isn't the service hole cover that metal plate under the carpet, behind the drivers seat that hides the fuel sender unit?
- Driver+Passengers
The name of the game is a "coolant change".
Then later...factsheet wrote: This is a summary of the procedure:
• remove air duct
• open service hole cover
• remove air bleed hose plug
• remove reservoir tank cap
• loosen radiator drain plug
• drain coolant
• etc...
Most likely, it means the passenger seat.factsheet wrote: If it seems OK, re-attach the air bleed hose to the body of vehicle, close the service hole cover and attach the air duct.
