Hi. I'm looking on eBay at fuel filters and they all seem to be labelled as 1995-2003, I have an M reg which is 94/5 . Are they all the same anyhow?
Is there a parts list somewhere? I plan on also doing a full service.
Which fuel filter for a 94/95 2.4 td?
Re: Which fuel filter for a 94/95 2.4 td?
They're all the same for any vintage of diesel Bongo. I believe there's a service factsheet in the members area. Also, Ian was doing a deal in the shop if you bought a complete set of filters. At least that way, you won't have any worries about them not fitting correctly.
Not necessarily, the filter head may have been changed - mine has at sometime in the past and so takes a slightly different filter from that shown on application charts.Simon Jones wrote:They're all the same for any vintage of diesel Bongo. I believe there's a service factsheet in the members area. Also, Ian was doing a deal in the shop if you bought a complete set of filters. At least that way, you won't have any worries about them not fitting correctly.
It could be worth taking the filter off and checking the number on it.
Hi dodgy,
The 3 filters air/oil/and fuel at eurocarparts for £20.53 delivered..Use Code 30NOW,they also give you the dimentions of the products if you want to compare,just enter your registration number in the box..
http://www.eurocarparts.com/car-parts?g ... tAodVGQAag
Cheers.
Cheers.
Niiiiiiiiiiiice! Thanks. Reserved at my local store for collection tomorrow.
Cheers!
Cheers!
