buzzer
germag
buzzer
Post by germag » Tue Oct 09, 2012 1:47 pm
Just picked up a Bongo and no electric mirror or ciggy socket working.
Fuse no 8 blown, replaced fuse and all ok except i have a continuous buzzer going off under the dashboard.
Pulled no 8 fuse and the buzzer stopped and so have the mirrors and ciggy socket.
Anyone have any idea what is making the buzzing sound?
Thanks in advance.
Gerald
Re: buzzer
Post by mikeonb4c » Tue Oct 09, 2012 1:58 pm
germag wrote:Just picked up a Bongo and no electric mirror or ciggy socket working.
Thanks in advance.
Gerald
Fuse no 8 by the sound of it, hence why someone removed it ha ha. But seriously, the Bongo has many beeps but no buzzers, as far as i'm aware. So I guess it must be something non-standard. Can you find the buzzer and identify relevant wiring. Geoff (g8dh or summat like that) is our resident wiring guru and may have a thought on this.
Driver+Passengers
Re: buzzer
Post by Driver+Passengers » Tue Oct 09, 2012 2:03 pm
What is the pattern of sound the buzzer makes?
Is it coming from the driver's side just to the right of the accelerator?
Is there a low coolant alarm fitted?
Image Image
germag
Re: buzzer
Post by germag » Tue Oct 09, 2012 2:19 pm
Thanks for a guick reply.
The sound is a continuous beep coming from under the left side of dashboard.
I think there is a low coolant alarm fitted as there is a single red wire on water bottle between high and low level
There is no sign of a warning light on the dashboard anywhere.
Hope this helps.
Driver+Passengers
Re: buzzer
Post by Driver+Passengers » Tue Oct 09, 2012 2:22 pm
germag wrote:Thanks for a guick reply.
Hope this helps.
Remove the glove box. There is a 2 inch rubber bung up under towards the left that leads through to the front, just behind the coolant header tank. If there is a wire coming through that grommet, then try tracing it.
Image Image
germag
Re: buzzer
Post by germag » Tue Oct 09, 2012 3:02 pm
Please bear with but it looks like spaghetti in there.
Red wire from expansion tank comes through bulkhead and is connected to a rocker switch o n the dashboard.
Second yellow wire from switch on dash goes to a black box behind glove box.
Two smaller gauge wires red and black come out of black box and are scotchlocked
To larger gauge red and black respectively .
That's as far as I,ve got
Does that make any sense to anyone.
germag
Re: buzzer
Post by germag » Tue Oct 09, 2012 3:05 pm
Sorry forgot to say that by flicking the rocker switch the noise stops.
mikeWalsall
Re: buzzer
Post by mikeWalsall » Tue Oct 09, 2012 3:17 pm
Strange if it is the low coolant alarm, to why anyone would fit a switch in the circuit to turn it off ..!!
Re: buzzer
Post by g8dhe » Tue Oct 09, 2012 3:21 pm
Sounds a non-standard addition, and it isn't the "normal" i.e. Haydn's - type of Low Coolant Alarm either!
There have been some very basic Low Coolant Alarms marketed that are just a Buzzer fed by a transistor- sometimes with an LED, and use a couple of screw in probes on the tank. It sounds as if it might be one of them which someone has put a switch in to disable it ... I can guess why!
germag
Re: buzzer
Post by germag » Tue Oct 09, 2012 3:35 pm
Yes I think your right inside the black box is a small buzzer and a circuit board.
Can anyone tell me where I can buy the real thing.
Thanks to all. =D> =D> :D
Gerald
Driver+Passengers
Re: buzzer
Post by Driver+Passengers » Tue Oct 09, 2012 3:37 pm
Have you checked your coolant level when cold?
Dip it with a lolly stick or coffee stirrer, you should have a couple of centimeters in there.
Image Image
germag
Re: buzzer
Post by germag » Tue Oct 09, 2012 3:41 pm
When picked up the bingo this morning there was about an inch of coolant measured of a stick.
Does that sound right.
Driver+Passengers
Re: buzzer
Post by Driver+Passengers » Tue Oct 09, 2012 3:50 pm
germag wrote:When picked up the bingo this morning there was about an inch of coolant measured of a stick.
About right, I think.
Image Image
Re: buzzer
Post by g8dhe » Tue Oct 09, 2012 5:25 pm
germag wrote:Can anyone tell me where I can buy the real thing.
See here http://www.igmaynard.co.uk/bongo/forum/ ... 86#p568686 there is a link at the bottom of Haydn post.
germag
Re: buzzer
Post by germag » Tue Oct 09, 2012 9:24 pm
Thanks to everyone for your help,have ordered a haydn coolant alarm tonight. :D :D :D
