Help - very dim headlights
Gethin
Post by Gethin » Mon Nov 27, 2006 6:54 pm
The light from our headlights was so poor we could hardly see the road.
We changed the bulbs for 100/80w bulbs but this has made little difference.
The headlamp glass is quite yellow inside, but not enough to warrant such poor light from the headlights.
Help - any suggestions?
pippin
Post by pippin » Mon Nov 27, 2006 7:04 pm
You may have the aftermarket dim-dip system fitted.
Look for a switch somewhere by the dash that you have wondered about its function in the past.
If you find it, switch it and see if all is revealed!
dandywarhol
Post by dandywarhol » Mon Nov 27, 2006 7:28 pm
You need to watch with some modern wiring looms - the fashion is to go for the thinest guage wire to do the job to save weight (the average large family car used around 6 miles of wiring before year 2000 :shock: )
If you fit larger wattage bulbs than the loom has been designed for all you get is the same light brightness but hot wires!!
Veg_Ian
Post by Veg_Ian » Mon Nov 27, 2006 9:00 pm
Yellow glass? Yes it's actually plastic and "discolours" over time due to the UV from the bulbs. Had a similar problem with my old Townace. Not much you can do really other than replace the units. I believe you can now get bulbs that filter out the UV.
white van man
Post by white van man » Mon Nov 27, 2006 9:08 pm
larger bulbs will create more problems as the plastic light will get too hot and discolour even faster,you can "t" cut the lamps and a thin protective film will come off making the lamps clearer,you could also fit xenon bulbs,not the cheap 2 for a tenner on ebay,the real mcoy as used on beamers and mercs ect,will cost about 250 to 300 to do properly but worth it if you do a lot of night driving plus they only use 35watts so are cooler and cause less discolouration ,nice white light to drive by
rwill19050
Dim lights
Post by rwill19050 » Tue Nov 28, 2006 12:22 am
Another problem could be the contacts in the headlights relay, corroded / pitted contacts would allow some current to flow (dim lights) but not enough to allow full' brightness'
On the other hand, I could be talking out of my exhaust pipe :?
