Steering rack.
brorabongo
Steering rack.
Post by brorabongo » Thu Aug 16, 2012 3:23 pm
Are all Bongo steering racks the same?
Mine is leaking. I can get a s/h rack, but does it matter if it's from a 2wd as mine is a 4wd?
On Lushprojects it lists 6 different racks. :shock:
Cheers.
P.S. Is it an easy-ish job to replace the seals? as I might refurb my old one in the future if so. :-k
ボンゴの激怒 pictures
Re: Steering rack.
Post by Northern Bongolow » Thu Aug 16, 2012 6:12 pm
ive fitted a few and am not aware of any external differences, but maybe i was just lucky.
as far as i know there is only one seal recon kit available??.
as to how easy a recon job is have a look in the manual--------its the largest single subject in there :shock: 30 odd pages if i remember right, plus lots of specialist/home made tools needed. #-o #-o :wink:
brorabongo
Re: Steering rack.
Post by brorabongo » Thu Aug 16, 2012 7:25 pm
Northern Bongolow wrote:ive fitted a few and am not aware of any external differences, but maybe i was just lucky.
Thanks.
Re the refurb...............I don't think I'll bother. :lol:
ボンゴの激怒 pictures
Re: Steering rack.
Post by Muzorewa » Thu Aug 16, 2012 8:10 pm
Re S/H rack if you get one from our local friendly (Friendee?!?) breaker, I'll be passing through Sutherland next weekend :idea:
brorabongo
Re: Steering rack.
Post by brorabongo » Thu Aug 16, 2012 8:42 pm
Thanks Muz.
Silly question though....Which friendly breaker are you thinking of? 8-[
ボンゴの激怒 pictures
Re: Steering rack.
Post by Northern Bongolow » Thu Aug 16, 2012 11:08 pm
Thanks.
ive got an old rack of mine, and a seal kit in stock, and im still not doing it. #-o #-o :wink: .
Re: Steering rack.
Post by Muzorewa » Fri Aug 17, 2012 2:43 am
brorabongo wrote:Thanks Muz.
http://stores.ebay.co.uk/bongobits4u :wink:
brorabongo
Re: Steering rack.
Post by brorabongo » Fri Aug 24, 2012 10:33 am
With a bit of luck in the timing (he was due to pass through Brora) Muz went out of his way to pick up a Steering rack from the above seller and drop it off at my door, at some time of this morning that I didn't know even existed!! :lol:
Many thanks Muz, Your a Star!! Image
Also thanks to George at http://stores.ebay.co.uk/bongospares2012 for the great service, and allowing Muz to pick up the rack from his house outwith working hours. =D>
Now only got to wait till the 11th to get it fitted. :(
ボンゴの激怒 pictures
Re: Steering rack.
Post by Northern Bongolow » Fri Aug 24, 2012 11:00 am
good one paul.
ever thought of becoming a paid courier. 8) :wink:
stuc
Re: Steering rack.
Post by stuc » Mon Aug 27, 2012 11:30 am
Hi I bought a s/h steering rack cos mine was leaking, now the s/h one is leaking twice as bad, wish I had just bought a new one to save changing it again.
rita
Re: Steering rack.
Post by rita » Mon Aug 27, 2012 11:46 am
stuc wrote:Hi I bought a s/h steering rack cos mine was leaking, now the s/h one is leaking twice as bad, wish I had just bought a new one to save changing it again.
might be worthwhile getting the pressure checked before you replace it (or seals) again.
Cheers.
stuc
Re: Steering rack.
Post by stuc » Mon Aug 27, 2012 8:12 pm
How would you check the pressure?
rita
Re: Steering rack.
Post by rita » Mon Aug 27, 2012 8:47 pm
stuc wrote:How would you check the pressure?
I would check the pressure with 2 pressure gauges,but if you dont have the equipment,your local garage should be able to carry out the tests.It is advisable to get a professional to carry out the procedure owing to the very high pressure that the pump produces.
Cheers.
stuc
Re: Steering rack.
Post by stuc » Tue Aug 28, 2012 10:04 am
Cheers.
Hi I have access to lots of equipment, so what kind of pressure gauges, where do they connect and can you adjust the pressure if it is too high?
rita
Re: Steering rack.
Post by rita » Tue Aug 28, 2012 10:39 am
stuc wrote:
Cheers.
Hi your gauges will need to have a capability of handling a min of 1500 PSI,with suitable high pressure tubes and valves,if you have these you can connect to the both ends of the rack/pump.Take the fluid temperature to 50/60%,be very careful.
PS do you have the equipment required.
Good luck.
