Does anyone know where the low oil level sensor is on the Diesel engine?....AND at what level does it operate the light????
Low oil warning light
- helen&tony
Re: Low oil warning light
Hi Helen. Could this help? (part 18-501) http://lushprojects.com/bongopartsmk2/c ... no=.html#4
Hi this is the low oil light sensor,dont know the trigger level,dont want to know.
107301
http://lushprojects.com/bongopartsmk2/c ... o=.html#17
107301
- Driver+Passengers
I believe that the light can be illuminated by either the oil level sensor or the oil pressure sensor.
For me, a level less than half an inch above the low mark would trigger the light only when going round a corner, or alternatively, would turn off when going round a corner the other way. I forget which way was which...
I think I read somewhere that a level half down the dipstick would trigger. Your mileage may vary...?
It would possibly cause a flicker of the light on a steep incline facing up too..?!!Driver+Passengers wrote:
- Driver+Passengers
18-501 is the pressure switch.jaylee wrote:Hi Helen. Could this help? (part 18-501) http://lushprojects.com/bongopartsmk2/c ... no=.html#4
10-7301 is the level switch.rita wrote: Hi this is the low oil light sensor,dont know the trigger level,dont want to know.
107301
- helen&tony
Thanks for that...The107301 is the baby...The pressure switch I'm not concerned with, as I'm "remote-ing" that , and I couldn't see the oil level switch....(can't get under the Bongo)
That little bit of info gives me some good scope for yet another gismo
