2.5l Diesel power loss/hesitating over 2500 rpm when acceler
Jezza
Post by Jezza » Mon Jul 30, 2012 10:47 pm
Hiya - got a 2.5l diesel and have noticed that when accelerating often when I go over 2500rpm there is a jerky hesitation like the power is dropping off then coming on again - especially when going up hills
Any thoughts as to what may be going on - fuel starvation, turbo issue, something else ? so I can go to the mechanic with something specific to look for and keep the cost down
thanks
Jezza
Simon Jones
Re: 2.5l Diesel power loss/hesitating over 2500 rpm when acc
Post by Simon Jones » Tue Jul 31, 2012 1:02 am
Check the filters: air, fuel & bango filter on the injector pump. Also try slackening the fuel filler cap in case you have a blocked breather.
adamjlowe1990
Post by adamjlowe1990 » Tue Jul 31, 2012 6:54 pm
i seem to be having the same problem tried loosening my fuel cap, problem still there
Jezza
Post by Jezza » Fri Aug 03, 2012 11:33 am
checked the fuel cap and made sure it was ok last fill, air filter seems ok - where are the fuel and banjo filters?
Jezza
Simon Jones
Post by Simon Jones » Fri Aug 03, 2012 3:14 pm
adamjlowe1990
Post by adamjlowe1990 » Fri Aug 03, 2012 6:17 pm
turns out mine was fuel pump again :roll:
adamjlowe1990
Post by adamjlowe1990 » Tue Aug 07, 2012 7:20 pm
did you fix the problem ? try the little strainer in the fuel pump
brorabongo
Post by brorabongo » Wed Aug 08, 2012 1:00 am
Another possible cause is the rubber U bend hose from the air duct onto the turbo, if it comes loose you may have those symptoms.
ボンゴの激怒 pictures
