My Leisure Battery Tray is too small :-( Replacement help?
Moderator: Doone
eppiblue
Post by eppiblue » Wed Jul 25, 2012 8:58 pm
Here I was about to buy a new 110Ah Platinum LB when I thought, 'hmmm, I should probably measure the LB tray I have'... :roll:
So turns out it's not very big. :oops: From the photos can anyone tell me if this is the standard Mazda near side (2nd battery) tray ?
Existing Dimensions L/W/H
85Ah Leisure Battery: 250x170x210 (at back and 185 at front, the terminals are in a recess)
Tray looks to accommodate: 270x170x190ish
I'm hoping I can just unbolt this thing and pull it out. I've been reading that Willinton supplies a large tray that can take a 110, can anyone advise if that would bolt into this space once this ones out? I've got some tools but no workshop, tho if it's not too tricky I'm sure I can do it. I don't think I can make my own tray and bracket.
'Vincent' - 1996 P reg - Green - 2.5 TD - 4WD - Likes: Diesel, Bitumen and Snow.
westonwarrior
Re: My Leisure Battery Tray is too small :-( Replacement hel
Post by westonwarrior » Wed Jul 25, 2012 9:25 pm
the willinton tray will fit straight in.
its made specificallly for the bongo.
eppiblue
Post by eppiblue » Wed Jul 25, 2012 9:47 pm
westonwarrior wrote:the willinton tray will fit straight in.
Great news, I'm assuming this little guy needs to be ripped out then
mikeWalsall
Post by mikeWalsall » Wed Jul 25, 2012 10:39 pm
That tray is an after market one .. similar to the one the converter fitted to mine ...
The simplest solution is a fibre glass Willinton version which is a simple fit to fit a 110ah battery ..
As I could not obtain a Willinton tray at the time I utilised a normal drivers side Mazda tray (exactly the same as the northern spec. second battery trayed Bongo) but I had to make a couple of 'Z' shaped brackets .. but all in all a simple and cheap alternative ..
Standard Mazda battery tray
Fitted with a 110ah leisure battery ..
eppiblue
Post by eppiblue » Tue Jul 31, 2012 5:38 pm
Confusing - there are 3 separate models of the Platinum 110Ah leisure battery.... http://justcarbatteries.co.uk/index.php ... eries.html
Is there any difference aside from sizing and which one is the best fit for the Willinton tray, as they all slightly breach it?! (345x175x235)
http://justcarbatteries.co.uk/index.php ... -110a.html
350MM LENGTH
175MM WIDE
225MM HIGH
http://justcarbatteries.co.uk/index.php ... ttery.html
354MM LENGTH
175MM WIDTH
190MM HIGH
330MM LENGTH
173MM WIDTH
240MM HIGH
mikexgough
Post by mikexgough » Tue Jul 31, 2012 5:43 pm
Sd 6110L is mine....
mikeWalsall
Post by mikeWalsall » Tue Jul 31, 2012 6:24 pm
When I did mine I found it was not the length or width that caused any problems
But as the battery as to fit under the drain channel up to the relays / inner wing, on my tray the maximum case hight that would fit (ie: excluding the lifting handles) .... was quite critical @ 9" ..
My 'normal' 110ah leisure battery is (about) 14" long x 7" wide x 9" high..
eppiblue
Post by eppiblue » Tue Jul 31, 2012 8:00 pm
mikexgough wrote:Sd 6110L is mine....
So you have the Platinum Plus SD6110LL
330MM LENGTH
173MM WIDTH
240MM HIGH
If so thats the one I'm getting :D
mikexgough
Post by mikexgough » Wed Aug 01, 2012 5:59 am
From This brochure you will see the SD6100L which I have and it has a centre mounted single handle..... my previous LB was like the twin handled one.
eppiblue
Post by eppiblue » Wed Aug 01, 2012 11:06 am
mikexgough wrote:From This brochure you will see the SD6100L which I have and it has a centre mounted single handle..... my previous LB was like the twin handled one.
and according to the pdf the SD6110L is a 328x172x214 so within the Willinton spec
Its also a dual terminal post, does that make any difference?
eppiblue
Post by eppiblue » Wed Aug 08, 2012 6:12 pm
For the sake of a completed thread, I just fitted the platinum SD6110L leisure battery in the willinton battery tray without any issues. There was a bit of room to spare as well. Thanks for everyone's help. :D
eppiblue
Post by eppiblue » Tue Aug 21, 2012 8:50 pm
and the finished product
eppiblue
Post by eppiblue » Mon Sep 17, 2012 5:42 pm
can anyone tell me what the little red plugs are at the top /side of the battery... do I need to remove these?
Post by g8dhe » Mon Sep 17, 2012 6:58 pm
Probably covering vent pipes in the event the batteries are allowed to gas during charging, as its a sealed job there are no caps with vents in them to release the pressure. If its not clearly marked to remove then I would leave them in place.
eppiblue
Post by eppiblue » Mon Sep 17, 2012 8:44 pm
g8dhe wrote:Probably covering vent pipes in the event the batteries are allowed to gas during charging, as its a sealed job there are no caps with vents in them to release the pressure. If its not clearly marked to remove then I would leave them in place.
Hmm, I think there may have been a slip of paper in the package showing how to remove them.... I think I will remove them
