Hello all
i am having an issue with my rear wiper not working i bought a new motor thinking this was the issue turns out the old one was fine after a quick test DoH!
anyway i checked the fuse thats fine is there anything else in the circuit other than the stalk/switch that i should check has anyone else had problems with the rear wiper before and what did you do to fix it?
advice please and some direction as i have checked wiring all seems ok just no life from the motors?
Rear Wiper wont work?
Re: Rear Wiper wont work?
Seems a common problems and usually tends to be the wiring where it passes from the body to the tailgate. Lots of info available via the search facility, but here's one example:
http://www.igmaynard.co.uk/bongo/forum/ ... er#p560300
Jimbob738
- Location: Jaaaaacksdale! but a nottingham boy throught and through! you reds
Hi simon thanks 1 hour later five broken wires in the rubber gromit and no number plate lights either but good new is i got the wiper working what a pain in the ass!
