My bongo is grounding out if loaded when if goes over speed bumps or bumpy ground. What can I do??
I thought it was the exhaust to start with but it is the two round bits next to the back wheels. I've got some photos but can't post them for some reason.
Banging bongo
benedmonds
- westonwarrior
Re: Banging bongo
common problem
you can get air assisters for the rear springs and I'm sure some one will come along with the correct type etc
Its cheaper than renewing the springs
- helen&tony
Re: Banging bongo
Air helpers from matt Savage:
http://www.mattsavage.com/acatalog/copy ... rings.html
Re: Banging bongo
see if you have the rear bump stops in place,one or more usually fall off. they are the 3 inch solid blocks of rubber bolted up to to the underside of the chassis, these hit the top side of the axle tube. if they are there you could remove them and fit a softer compound rubber block. works well for our 2 bongo's. same size , just a softer hit.
Re: Banging bongo
I fitted these a couple of months ago and they have transformed the rear end. The Bongo used to wallow a bit going round country lanes and bottom out going over speed humps. Fitting these has cured both problems.
Fitting is not quite as easy as their video would suggest although I managed in just over an hour.
http://air-lift.co.uk/selectproduct.php ... odel=Bongo
Brian
Brian
Re: Banging bongo
Mine bottoms out when loaded too. These look just the ticket. Looking at the installation instructions they look straightforward, but are there any top tips. Also what psi for general use cheers rob
Re: Banging bongo
I use about 45/50 psi which seems to cope even when loaded. I think the instructions say you can go as high as 100 psi but I'd guess at that pressure you'd have a pretty harsh ride.
As for installation, the instructional video on the site explains it all quite well but I'm sure the bloke doing the fitting has done it a hundred times before. The actual bags are very tough vinyl which is quite difficult to manipulate through the coils. Strong fingers are needed and a tool such as a tyre iron is essential.
Oh and put the hose on at the bottom, not the top, you'll see why. Make sure you use the correct spacer at the correct end. Its not that clear. I can't remember which is which but e mail the supplier and they will explain.
Brian
Brian
Re: Banging bongo
Cheers thanks for the tips
