mikeonb4c wrote:rhino-wayne wrote:Hi all,
just about to try & fix Bongo's  "parking Brake lever has no reserve travel" MOT fail. Could only find a couple of locked threads from 2007 on the forum.
Any hints, tips, photos etc would be much appreciated ..
Check & adjust only via the parking brake drum on rear wheels? or is there some adjustment to the cable/lever area?
thx
3 adjustments, do them in this order
1) drum 'star' adjusters, so drum linings are not quite binding
2) 2 x cable adjustments underneath car where handbrake cable splits into cables for each wheel (slacken off handbrake cable and handbrake end first so you have plenty of reserve there for when you might need to make quick subsequent tightenings for MOT etc
3) adjuster by handbrake lever
hope this makes sense. It's all easy stuff
Ok so as you say all things were "easy Stuff".........
following the fact sheet advice of "locate" the star adjuster by turning the wheel.....i did just that.........I probably turned the wheel 350 degrees !
  before finding the said adjuster
I "located" mine at the bottom, thru' that hole with rubber bung removed
While I was there took a photo of point 2 (where the 2 cables join):
Anyway, that's to all who helped............Passed the MOT
