V6 exhaust system
TerryG
V6 exhaust system
Post by TerryG » Sun Jun 24, 2012 5:03 pm
Anyone know where I can buy a V6 exhaust front section? Just managed to poke my finger through a rust spot, which suggests it's not long for this world. There seem to be plenty of places supplying systems for the diesel but I can't find anyone doing them for the V6 - in particular the front section.
Thankee kindly
'Enjoy every sandwich'
cheffy34
Re: V6 exhaust system
Post by cheffy34 » Tue Jun 26, 2012 9:23 am
if the rest of it is ok get someone to weld a patch on it :!: The front section has the cat pipe aswell or do you mean the section after the cat :?:
TerryG
Post by TerryG » Tue Jun 26, 2012 9:47 am
cheffy34 wrote:if the rest of it is ok get someone to weld a patch on it :!: The front section has the cat pipe aswell or do you mean the section after the cat :?:
I mean the section in front of the cat section, ie. the 'forked' section that comes down from each bank of exhaust manifolds.
cheffy34
Post by cheffy34 » Tue Jun 26, 2012 4:18 pm
Sure isnt just the heat shield you poked your finger through, if not a patch woud be the way forward or a second hand one new will be mega bucks i fear as it's the down pipes manifold inckluded if i remember right.
Dar
mikeWalsall
Post by mikeWalsall » Tue Jun 26, 2012 4:25 pm
TerryG
Post by TerryG » Wed Jun 27, 2012 1:41 pm
cheffy34 wrote:Sure isnt just the heat shield you poked your finger through
Dar
Could be - is that section of pipe double-skinned, ie. with an integral heat shield?
rita
Post by rita » Wed Jun 27, 2012 3:03 pm
If you have a hole in the down pipe it will probably be very noisy and might even spit a wee flame out.
cheffy34
Post by cheffy34 » Wed Jun 27, 2012 6:27 pm
Dar
Yes it is integral :!: mine is rotten to buggery :roll: rita is right it would be making hell of a racket aswell, it will also cause havoc with your emmissions/fueling as it will drag air in past your lambda sensor causing the ecu to compensate
Dar
TerryG
Post by TerryG » Thu Jun 28, 2012 9:32 am
cheffy34 wrote:
Dar
Dar
Phew, panic over - the cheque book can come out of hiding!
Thanks all for your knowledge.
SimonT
Post by SimonT » Thu Jun 28, 2012 5:22 pm
Glad to hear its sorted Terry.
Its a good question though.
Does anyone know if it is it possible to source an exhaust system from the front pipe to the back for a V6?
Simon from Exeter
Bongotastic !!
mikeWalsall
Post by mikeWalsall » Thu Jun 28, 2012 6:03 pm
MIJ here in Walsall West Midlands have a good reputation in Bongo stainless steel exhausts ..
Although this eBay one is for a diesel .. as each one is custom made I assume that a V6 would be no problem ..
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... 335bd0faea
Or maybe autojapspares could source a full system ..??
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 1c279e9c79
SimonT
Post by SimonT » Thu Jun 28, 2012 9:49 pm
Thanks Mike,
Much appreciated. :)
Simon from Exeter
Bongotastic !!
buddyh42
Post by buddyh42 » Fri Jun 29, 2012 12:15 am
My exhaust went at the start of the year and it was only an extra £80 to get a custom steel one made by RJM in Glenrothes, dont know how much was replaced though
That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
