a smell of gas but outside the van? weird V6
Hi, just been a quick run to the shops and driving there I thought I smelt gas, when we arrived Mrs H got out and said she could smell it now, I got out popped the lid and sure enough there was a very strange smell, the best way i could describe it is like gas or peeled onions, I am puzzled anyone any ideas what I am smelling or if there is something wrong if so how to fix it, Cheers
That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
Re: a smell of gas but outside the van? wierd
Petrol or diesel engine? The catalytic converters in petrol exhausts can smell 'eggy' when warming up, or when there is unburnt fuel in the exhaust gases. Alternatively, did you buy an onion at the shop and stuck it somewhere warm
Petrol V6, if it is the cat will it clear itself or do i need to do something, sorry bout the stupid questions but i know absolutly nothing when it comes to cars. Cheers
Iwannabongo
- Bongonaut
Could be a few things. First I would try a better quality fuel and give the engine a good blasting. Check the battery/batteries as if they are on the way out, can give off sulphur fumes. Lastly could be the catalytic converter on the way out or just needs an italian tune up to burn off excess sulphur.
Hi buddy,you dont have a LPG conversion or a gas canister/lighter gas onboard ??.
If not I would check that the engine is firing 100% on all cylinders,if it is not it could be dumping unburnt fuel into the Cat and causing it to burn (smell) or oil leaking onto the exhaust.
Cheers.
Cheers.
Boiling coolant?buddyh42 wrote:I got out popped the lid and sure enough there was a very strange smell, the best way i could describe it is like gas or peeled onions...
It's a while since I last smelt it to be able to compare it to onions but it smelt strongly enough to alert me before I fitted an alarm.
Frank
They flew, I took up naturism
MountainGoat
This does not seem to bode well Buddy. I hope that you have one of Hyden's low coolant alarms fitted to your Bongo if not get one from Hyden as soon as possible. If it is not the coolant then you had best take your Bongo round to campercraft to have it checked over.
Tony
Tony
Hi people, its not coolant as checked that and also got a H aydyn alarm, also got gas bottle inside but not that as no smell inside, was gonna have a look today but was ill so hopefully see to it tomorrow, thanks for your suggestions all welcome and will keep you all posted. Hi Tony hope your well need a catch up soon.
Well i have had a good look in the engine and all the nuts on the cylinder head had oil leaking around them so i was anicking up until i touched them and they were all just hand tight, so i tightened them all and since then and cleaning the engine no smells at all.
Head bolts
or rocker cover nuts?
Had a mechanic friend have a look for me and he says it is rocker cover, me I know jack about engines just knew something should not have been as slack as what they were, some were that slack that they would have been as well not there.
