mrsam wrote:The cable with the 4 wires is the one you need.The red and black wires feed the 12 volts into the control panel.The other 2 wires, green I think, carry this  voltage to the motors  Oneway to lift the other way to lower the roof.The relays and switches set which way round the Voltage is. There are 2 fuses used 10 and 12 I think, one is the feed for the control panel the other for the motors. If there is no sound from the motors check these fuses. Putting 12 volts across the green wires feeds the motors direct and you shoul hear them.
Cheers - will be looking at this later today - so I understand from you that
Red/Black - controller feeds
Other two (poss green) in same cable are live/neg feed to BOTH motors? - obv. reversible.
Only other thing I've heard about is being aware if one motor goes on it's own, and consequently twisting the roof (though I thought the two motors pushed the same transmission - i.e. helping each other, rather than having a side each?)
