Ok so before I end it all and find a cliff, I have a problem with my bongo. I have posted before on here about this but thought a fresh post would be the way to go.
The bongo stalls but only when cold. It can be best described as driving a manual without using the clutch when you are supposed to resulting in a rather aggressive stall. It does it in reverse, in drive (or any other mode) but ONLY when cold. Now I have just had the bongo back from Dunning’s after replacement of the lockup solenoid but that hasn't solved the problem. They thought it had as they were not picking up the rev's enough to cause the stall. When tested at the workshop after the work was carried out the mechanic only pulled away several feet and didn’t work the engine hard enough. Now this morning at home getting it off the drive, which takes a bit of rev the bloody thing stalled. For some reason it feels a lot better (I guess due to new filter / oil change in gearbox) but the nasty problem is still there. Before I have to go down the road of a re-con at £1250 + VAT could anyone suggest anything else to look at?
Please help out a fellow unhappy bongo owner.
Pete
Automatic stalling still, Can anyone help PLEASE
Re: Automatic stalling still, Can anyone help PLEASE
diesel or petrol
link to past threads
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=42466 and http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=52712
Its a 2.5 4wd turbo diesel
Sorry, lack of coffee this morning and fed up!
Pete
Pete
my money would be on fuel, the temp thing is prob a red herring.
my friends did similar for 6 bloody months, it turned out to be fuel filter, new cheap/faulty one fitted, still the same, fitted good quality one fitted sorted.
try it on the drive with a can of fuel piped direct to the pump, bypassing the filter/housing etc. if no better then look at the pump. shot tps, leaks.
Hi opp_uk,
It sounds very much like the box is selecting a Too high a gear or in direct drive until the atf gets going.
There is a Auto box specialist on here cant remember name at present,would be worth a shout.
Cheers.
PS Alacrity is the Man..
Cheers.
Thanks for reply peeps, it is time I serviced it so will change fuel filter, needs it done anyway! I will contact alacrity or hopefully he may read this! Many thanks again for input.
Pete
Pete
