Fitting a radio/CD to the Bongo
- Tribal Elder
Unable to locate the thread on advice for replacing the japanese radio on my soon to be supplied bongo.
Seem to recall a part No. from halfords for some kind of adaptor to convert to european radio CD units.
Halfords quote prices for fitting to various models of cars but the bongo is not listed. However our local halfords may fit if I can supply the colour code/wiring diagram plus the part No of the adaptor.
"Today's rain is tomorrow's Whisky"
Re: Fitting a radio/CD to the Bongo
Think this is what you`re after....Gardener wrote:Unable to locate the thread on advice for replacing the japanese radio on my soon to be supplied bongo.
http://www.ebay.co.uk/itm/PC2-10-4-Mazd ... 2314c0d2c7
You could probably tripple the price in Halfords,and i bet it is exactly the same part,i`ve used the Ebay ones many times before with no prob`s.....
Year 2000 V6
That part was £8 in Halfords about a year ago when I got mine.
It literally plugs in to the existing loom.
It has two earths so you need to find a point behind the radio to connect to.
Simple enough job.
Fit the cage, bent the slots to keep it tight, connect the earth, connect the harness, connect the aerial, push/plug in and away you go.
To be safe disconnect the battery first as there is a permanent live in the harness.
Simple enough job.
- Tribal Elder
Bongo?? wrote:Think this is what you`re after....Gardener wrote:Unable to locate the thread on advice for replacing the japanese radio on my soon to be supplied bongo.
Exactly what I was looking for many thanks.
- Tribal Elder
FunkyD wrote:That part was £8 in Halfords about a year ago when I got mine.
Simple enough job.
Fit the cage, bent the slots to keep it tight, connect the earth, connect the harness, connect the aeril, push/plug in and away you go.
Will try e-bay first probably same part, many thanks for fitting instructions should manage ok .
Just be aware there are two types - I got the PC2-10-4 only to find it was wrong - I ended up with a PC2-78-4
V6 Mushroom
Its to do with the year of the vehicle, they changed in 2000, from the 2 connector type, to the single type,so aero's all have 1 connector
Julian
Julian
- Tribal Elder
[quote="mantaJim"]Just be aware there are two types - I got the PC2-10-4 only to find it was wrong - I ended up with a PC2-78-4[/quote
It is the PC2-10-4 i am looking for is that correct?
- Tribal Elder
321Away wrote:Its to do with the year of the vehicle, they changed in 2000, from the 2 connector type, to the single type,so aero's all have 1 connector
Julian
Mine is a 96 model,haven't changed radio yet as awaiting delivery just wanted to get correct connector prior to delivery, which one do I need. Is it the PC2-10-4
Thats corect, you want a pc2-10-4, less than fiver on ebay
Julian
Julian
