When we bought our Freda we noticed the coolant level was well above the full mark. Now four months later it's still above the full mark but has come down a little.
Is this normal and will we just need to top it up from time to time or should the level never change unless there is a little leak?
Sara
How often should I top up my coolant?
- mountainmummy
Why, oh why did I chose such a naff forum name????
- daveblueozzie
Re: How often should I top up my coolant?
The coolant should be just up to the full mark, ideally it should not lose coolant, but quite a few of us do top up from time to time.
Lost without my Bongo.
- Muzorewa
Also it depends when you check, it'll be lower when cold and higher with a hot engine. Ideally fill to 'high' when cold and it'll be above the mark once warmed up, then drop back to the line when it cools.
- rhino-wayne
Probably a good habit is to check the coolant level on a daily basis (i.e. before 1st drive of the day)
- Muzorewa
A low-coolant alarm enables you to have peace of mind that the level hasn't dropped too low - ours loses a bit of coolant but then we do a lot of miles. Every two or three months we'll get a chirp telling us to top it up
I always check mine amongst other things before leaving for a big trip. That said the coolant on my Bongo has never ever needed toped up. It is all down to maintenance and everything running just as should. That said I do have a low coolant alarm fitted and a high coolant alarm waiting to go on.
I do carry around a small bottle of made up antifreeze just in case I ever do need a top up, I guess that is why I never need one. Just waiting for the day when I forget to take the top up bottle with me.
Tony
Tony
